16F84A EEPROM Programming
Results 1 to 8 of 8
    Exclamation
    Thanks, steve
    But it's already done ... ( also default setting, i think )
    Even microchip tell me to erase device before re-programming...so, it's a real bug !!!
    As their SSR 19753 says clearly EEPROM ERase doesn't work with 16F628, 16F84 and 16F876 ... what to do ?
    Really Funny ... isn't it !!!
    nop it's not a default setting.
    I still don't understand why Microchip don't offer, like many other programmer software, this 'erase before programming' option... well MPLAB is free
    i was not aware of this SSR 19753... so i guess you must clear them manually directly in the View>> EEPROM , right click on the window and choose Fill memory
    Talking
    Sorry Steve ... doesn't work either !!!
    All Other values ...except FF !!!
    Oh my gooood!!!
    fill memory with FF
    Programmer>>Setting
    uncheck auto select memory areas and range
    check EEPROM data
    program your PIC... read it back... you're now in business
    Talking
    Hi, Steve
    Seems impossible to write FF ( or erase ) to the EEPROM ... I had tried this way too ... memory window just can show his red face !!! no more.
    I think, I have to wait for the 7.02 Release ...
    Have a nice day
    Smile
    Hi, Everybody
    Here is the answer from Microchip :
    Comments:
    You are correct, regarding SSR19753, even though the PIC16F84A is not mentioned. I have informed the development systems group about this.
    The enhancement to erase EEPROM is planned for MPLAB IDE v7.20.
    Currently:
    Issuing an Erase when the device has been code protected will clear the entire device of data. A Blank Check will state the device is blank
    Programming the entire device with new data will change all memory areas. If for example this data were the reset values, a Blank Check after programming would reflect the device is blank.
    So must we do ...
    Good quiet night to you, folks ...
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 02:46
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
