CAn't get PLL to work on 18LF4620
Results 1 to 7 of 7
    Give this a shot
    @ __CONFIG    _CONFIG1H, _OSC_INTIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    @ __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    @ __CONFIG    _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    @ __CONFIG    _CONFIG4L,  _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE OSC 32
    OSCCON = %01110000
    OSCTUNE = %01000000
    Default ERROR Overwriting previous address contents
    Thanks Dave,
    I pasted your lines of code into my program but now I get a slew of
    "ERROR Overwriting previous address contents" messages. Not sure how to handle this.
    Cheers
    BrianT
    When setting the configs in code space you need to modify the *.inc file for the chip in the PBP directory. Comment out the configs there. Or just modify the *.inc with the new configs.
    http://www.picbasic.co.uk/forum/cont...o-your-Program
    Default Will stick with USB Programmer fuse settings
    Thanks Dave but changing the .inc file is more pain than gain.
    This little project has three 18F4620. One uses IntIO2 at 4 MHz which is where I want to activate the PLL, another uses HS with a crystal at 20 MHz and the third uses XT with a crystal at 4 MHz. It is easier to just change the Config fuses on the MeLabs USB serial programmer.
    Cheers
    Brian
    That is why I comment the *.inc and set the fuses in code space.
    But did you get it working like you want?
