Dial switch diemna... need more ANalog ports
Results 1 to 6 of 6
    Sep 2006
    Default Dial switch diemna... need more ANalog ports
    hello,
    I I am using the pic16f88 and I do not wish to change chip, but my dilemna is that I need more analog port. I want to add a selection button, where if you set the dial button on 1 it will put AN1 high, if dial button is set on 2 then AN2 will be high etc...
    I need 7 selection (so seven input pin) but I am only left with 3 ports to use.
    Is there anything like a analog to digital switch? or an alternative to either the switch or anything else that will give the same result?
    thanks
    K
    Maybe use the POT or RCTIME command.
    Sep 2006
    yes I need a pot switch, But I never seen one that has grooves in them so it do not change position by its own .. does that exist??
    K
    They do exist and I think is called detent.
    Look in ALPS.
    Nov 2007
    West Covina, CA
    Default Use only 1 A/D
    You can configure your own "switching" pot with a 7 position switch and resistors then use only 1 A/D port.
    Name:  7 Pos SW.jpg
    The values selected were not calculated for anything special just picked something that would probably give a decent spread for a 10bit A/D setting. Then using the SELECT CASE, set the values to the level "between" each setting.
    Suppose position 1 value is 170 and position 2 is 327 then make your 1st CASE setting to 248, middle of the two values, and continue from there for the whole range.
    Sample code:
    check_switch:
        ADCIN #, adval
        SELECT CASE adval
            CASE IS < xxx: do this or that   ' Lowest value
            CASE IS < xxx: do this or that   ' Highest value
        END SELECT
    I just made this a couple of months ago and works as needed!
    Louie
    Sep 2006
    thats agood idea, I used a similar switch arrangment but I will drop my if then statement and use Select case, I dod not know it was in picbasic, I used it in C++ a long time ago.
    thanks
    L
