serial problem
Results 1 to 5 of 5
Thread: serial problem
    Nov 2010
    Default serial problem
    pic18f2620.
    uart connected to rfid reader
    port a.3 and a.4 used for serial comms
    port c.5 and c.6 used serial to communicate with serial to network adaptor.
    all serial communication works fine.....except...... when i try to send data on c.5 no data is transmitted
    However if i leave program Define's and delete program except:
    SEROUT PORTC.5, [tagnum,pcount,tcount,stat]
    it works...???...???
    I Am fairly new to picbasic and now totally lost..........
    HELPPPPPPP Please
    Without seeing your code all we can do is guess. The configs will also help.
    Default Needs a MODE number
    The SEROUT command format is
    SEROUT pin, mode, [var1, var2...]
    You don't appear to have any MODE specified so no speed is specified.
    HTH
    BrianT
    Nov 2010
    THANK YOU!!!!!
    i mis-typed copying from test program into main program and was having a moment of number blindness............lol
    That is the weird part.
