Thermostat
Results 1 to 16 of 16
Thread: Thermostat
    Th relay footprint is common and you can find all flavors of relays.
    Another solution is to use an external 24V relay and then drive your 220 volt load.
    Ioannis, thank you very much for your reply.
    So do I understand correctly that one option is to replace the relay with another one that's for example 12v / 220v?
    You are correct.
    Have a look at digikey, farnell or you favorite provider.
    Thank you very much, I really appreciate it!!!
    malc-c's Avatar
    malc-c Guest
    Or you could use an opto-isolator and Triac to switch the mains voltage. The advantage of a relay is that it's fairly safe, but the noise from being energized could send you an your parrot bonkers !
    Thank you Malc
    I don't want to blow anything up, so I must make sure I do the right thing!
    Will it work if I replace my Relay with this one http://za.rs-online.com/web/search/s...duct&R=3998225
    Thank you !!
    malc-c's Avatar
    malc-c Guest
    Default Triacs
    Can't say for sure... from the spec I would say that should work - the Coil is 12v and the contact 240V and it appears that the contacts are rated at 10A, but then the tracks on the PCB have been designed to carry 24v at max 3A, so placing 240v at upto 10A could fry the board and obviously if left exposed is dangerous.
