Working clock example using 32K watch crystal
Results 1 to 20 of 20
    Boston MA
    Alain,
    Darrel's great example uses one crystal mine uses 2. And oh if something is sitting there soldered to the dev board and you don't have code to see if it works!!
    Quote Originally Posted by timc View Post
    Alain,
    Hi, Timc
    Lol ... I didn't remember I had modified Darrel's code to use a 32 Khz Xtal ...
    and thought it was already done in the original release ...
    Here it is.
    There's a couple good examples. I like Bruce's.
    But it uses in-line assembly language instead of straight PBP.
    The Elapsed Timer modification is nice too ... but ...
    Nobody wins the LCD's.
    Sep 2009
    Default Re: Working clock example using 32K watch crystal
    I was playing with TimC RTC code, and I found 1 problem...
    If the interrupt occurs between these lines
          GoSub get_time      ' Update minutes and seconds
          TOGGLE LED_0
          LCDOut $fe,2,"Time: ",DEC hours, ":", DEC2 minutes, ":", DEC2 seconds, "   "
    There is a chance to show 60 seconds.
    It happened to me, so I then wondered what was going on...
    Solution:
    seconds        VAR BYTE bankA  ' variables within myint must be in bank 0.
    minutes        VAR Byte bankA       ' Elapsed minutes
    hours          var byte bankA
    @myint                  ; create myint label
       TMR1H.7=1
        seconds = seconds+1  ' Increment second
        if seconds > 59 then
            seconds = seconds - 60    ' better then making seconds=0
            minutes = minutes + 1
            if minutes > 59 then
                minutes = 0
                hours = hours + 1
                if hours > 12 then hours = 1    ' simple 12 hour clock format
     PIR1.0=0             ' Clear TMR1 int flag
       @ retfie  FAST
    And remove get_time procedure
    Sep 2009
    I'm trying to add the calendar.
    Does anyone have an idea how to make a calculation of leap year.
    I tried this
    If day>30+month.0 or (Month=2 and day>28 and year//4<>0) or (Month=2 and day>29 and year//4=0)then
    month=month+1
    but the code is 300b larger then this
    If day>30+month.0 or (Month=2 and day>28)then
    month=month+1
    Is there a more efficient way?
    How about using 3 If-Then's insead of one with 3 OR's?
    Sep 2009
    I spent all night trying to find the best way ... I think this is
                  If month=2 then
                     If year//4<>0 then
                        DMonth=29
                        DMonth=28
                  Dmonth=30+month.0
                  If day>Dmonth then
    @                CLRF _Day
    @                INCF _Month,F
                     If month>12 then
    And everywhere there is any = 0, I replaced the @ clrf, +1 replaced with @ incf.
    The end result was the RTC which consumes about 2uA and code size about 500B.
