Working clock example using 32K watch crystal
Results 1 to 20 of 20
    Default Re: Working clock example using 32K watch crystal
    If I may suggest, make the minutes and hours update in your main loop and not in Interrupt. A temp variable wll be needed for this.
    Sep 2009
    If pic loses power, it goes to sleep. And everything is shut off, only tmr1 is on. So i need that in ISR. Is there better way?
