I was playing with TimC RTC code, and I found 1 problem...
If the interrupt occurs between these lines
There is a chance to show 60 seconds.Code:GoSub get_time ' Update minutes and seconds TOGGLE LED_0 LCDOut $fe,2,"Time: ",DEC hours, ":", DEC2 minutes, ":", DEC2 seconds, " "
It happened to me, so I then wondered what was going on...
Solution:
And remove get_time procedureCode:seconds VAR BYTE bankA ' variables within myint must be in bank 0. minutes VAR Byte bankA ' Elapsed minutes hours var byte bankA : : : @myint ; create myint label TMR1H.7=1 seconds = seconds+1 ' Increment second if seconds > 59 then seconds = seconds - 60 ' better then making seconds=0 minutes = minutes + 1 if minutes > 59 then minutes = 0 hours = hours + 1 if hours > 12 then hours = 1 ' simple 12 hour clock format endif endif PIR1.0=0 ' Clear TMR1 int flag @ retfie FAST
