Working clock example using 32K watch crystal
Results 1 to 20 of 20
    Boston MA
    Default Working clock example using 32K watch crystal
    Looked all over trying to find an example with a second crystal connected to the TIMER1 overflow. This example uses the earlier 18F452 version of the Olimex PIC-WEB board. Ran the clock for a day without gaining or loosing a second! Lots of places where I was not sure what to do. Comments are welcome.
    Tim C
    ' Name        : TMR1CLK.pbp
    ' Target PIC  : PIC18F452 or similar 18F types
    ' Hardware    : PIC-WEB ver A board with added LCD
    ' Oscillator  : 10MHz crystal. You May have to modify default 18F452 fuses for > 4Mhz
    ' Resolution  : Expect to get +- 5sec/day or better
    ' Description : PicBasic Pro program using external 32K watch xtal and Timer1
    ' interrupt for a real-time clock.
    ' Origional ver from: http://melabs.com/resources/samples/18f/tmr1clk18.htm
    DEFINE      OSC 10          ' We're using a 10MHz oscillator
    DEFINE      LOADER_USED 1   ' Boot-Loader is being used
    Define		INTHAND myint	' Define interrupt handler
    Symbol		LED_0 = PORTD.5
    symbol		BUTTON_0 = PORTB.0
    wsave		VAR BYTE bankA system   ' Saves W
    ssave		VAR BYTE bankA system   ' Saves STATUS
    seconds		VAR BYTE bankA  ' variables within myint must be in bank 0.
    minutes		VAR Byte      ' Elapsed minutes
    hours		var byte
    ' LCD config
    Define  LCD_DREG  PORTD
    Define  LCD_DBIT  0
    Define  LCD_RSREG PORTE
    Define  LCD_RSBIT 0
    Define  LCD_EREG  PORTE
    Define  LCD_EBIT  1
       ADCON1 = 7          ' Set PORTA and PORTE for digital operation
       Low PORTE.2         ' Enable the LCD
       Pause 150           ' Pause to allow LCD to initialize
       LCDOut $fe,1        ' Clear LCD
    	hours = 2
    	minutes = 23       ' Pre Set time here then add seconds to clock using button
    	seconds = 0
    	T1CON.7=0	' 8 Bit r/w (16 bit seems to cause problems)
    	T1CON.5=0	' Part 1 of 1:1 prescale
    	T1CON.4=0	' Part 2 pf 1:1 prescale
    	T1CON.3=1	' turn on the low freq clock osc
    	T1CON.2=1	' Do not Sync low Freq clock with main clock
    	T1CON.1=1	' use 32Khz xtal as the Timer1 source
    	T1CON.0=1	' enable Timer1
    	PIE1 = $01         ' Enable TMR1 overflow interrupt
    	INTCON  = $C0      ' Finally Enable global interrupt and peripheral interrupts
       GoTo mainloop          ' jump over the interrupt handler and sub
       ' Assembly language interrupt handler
    Asm
    myint
       ; Save the state of critical registers
       movwf   wsave      ; Save W
       swapf   STATUS, W  ; Swap STATUS to W (swap avoids changing STATUS)
       clrf    STATUS     ; Clear STATUS
       movwf   ssave      ; Save swapped STATUS
       ; Set the high register of Timer1 to cause an interrupt every
       ; 32768 counts (2^15).
       movlw   080h       ; Prepare to set TMR1 high register
       movwf   TMR1H      ; Set TMR1H to 80h
       incf    _seconds,F ; INCREMENT seconds COUNT
       bcf     PIR1, 0    ; Clear interrupt flag
       swapf   ssave, W   ; Retrieve the swapped STATUS value (swap to avoid changing STATUS)
       movwf   STATUS     ; Restore it to STATUS
       swapf   wsave, F   ; Swap the stored W value
       swapf   wsave, W   ; Restore it to W (swap to avoid changing STATUS)
       retfie             ; Return from interrupt
    EndAsm
    ' Subroutine to update the time variables
    get_time:
    	if seconds > 59 then
    		seconds = seconds - 60	' better then making seconds=0
    		minutes = minutes + 1
    		if minutes > 59 then
    			minutes = 0
    			hours = hours + 1
    			if hours > 12 then	' simple 12 hour clock format
    				hours = 1
    mainloop:
    	GoSub get_time      ' Update minutes and seconds
    	TOGGLE LED_0
    	LCDOut $fe,2,"Time: ",DEC hours, ":", DEC2 minutes, ":", DEC2 seconds, "   "
    	Pause 300           ' Pause to see LED blink. Also help with debounce
    	if button_0 = 0 then
    		LCDOut $fe,$C0,"+1s "
    		seconds = seconds + 1
    		LCDOut $fe,$C0,"     "
    	GoTo mainloop       ' Repeat main loop
    malc-c's Avatar
    malc-c Guest
    But 50% of the program is in assembler
    Quote Originally Posted by malc-c View Post
    Then show him how it's done. (in straight PBP)
    This task is worth 2 free 4x20 Parallel LCD's ... shipping outide of US/Canada extra.
    In case of multiple responses ... style will prevail.
    As judged by Darrel Taylor
    Ends 11/10/2010 Midnight Mountain Time
    Talking Naw only just point the way
    INCLUDE "DT_INTS-18.pbp" ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.pbp" ; Include if using PBP interrupts"
    Boston MA
    The earlier versions I wrote had NO asm but lost almost a minute an hour. To make up for that one could re-tune using TMR1H and TMR1L with a larger value. Problem is every change made to the program would mean spending a few days retuning and it would never be as precise.
    So yea I would love to be able to do this without asm in PBP AND be as accurate!
    Down the road I intend to join this interrupt sample with a SNTP internet program so I can have a near perfect millisecond low power $60 clock.
    Tim C
       ' Int handler doesn't mess with any PBP system variables - or lower 15-bits
       ' of TMR1 accumulated time. Uses only 4 instructions to set TMR1H high bit,
       ' increment seconds, clear the interrupt flag bit, save & restore WREG, STATUS,
       ' BSR and return from int handler.
    @myint                  ; create myint label
       TMR1H.7=1            ' Set TMR1 high bit for 1 second overflows
       seconds = seconds+1  ' Increment seconds
       PIR1.0=0             ' Clear TMR1 int flag
       @ retfie  FAST       ; Return with 'auto restore' of WREG, STATUS and BSR
    Should do it.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    malc-c's Avatar
    malc-c Guest
    I wish --- (I'll remove my tongue from in my cheek now )
    Boston MA
    Thank you Bruce
    Smaller, tighter, yet perfect speed. Started the clock last night with your change and so far the PIC18F452 has not gained or lost one second.
    Tim C
    I didn't see that one :
    http://www.pbpgroup.com/modules/wfse...hp?articleid=8
    did I miss something ???
