Error[126] c:\PBP\PBPPIC14.LIB : Argument out of range (2054 not between 0 and 2047)
Results 1 to 8 of 8
    Oct 2010
    Default Error[126] c:\PBP\PBPPIC14.LIB : Argument out of range (2054 not between 0 and 2047)
    I'm using PBP 2.60A, with MPLAB v.8.53, MPASM v5.36, on a Window 7 machine. This works fine for many programs. But then I have a larger program (Lines Assembled 11421)
    I'm getting the following:
    ERROR: Unable to execute mpasmwin.Message[306] C:\PBP\PBPPIC14.LIB 661 : Crossing page boundary -- ensure page bits are set.
    Error[126] C:\PBP\PBPPIC14.LIB 743 : Argument out of range (2054 not between 0 and 2047)
    Message[306] C:\PBP\PBPPIC14.LIB 743 : Crossing page boundary -- ensure page bits are set.
    Halting build on first failure as requested.
    BUILD FAILED: Fri Nov 05 18:02:20 2010
    Am I out of memory or something?
    Oct 2010
    Red face Out of Memory (Confirmed)
    Yep, sorry for the post. I was out of memory. I have never seen the out of memory condition with this set up. It's nice to know what it looks like.
    Regards.
    Mar 2005
    CROATIA
    Default Re: Out of Memory (Confirmed)
    Hello,
    I'm using PBP 2.60C, with MPLAB v.8.84, MPASM is from mplab installer, on a Window 7 machine
    I'm using pic18f4685 which is pretty large on resources, but after more than 1000 lines of code seems that there is no more space ?!?
    if i erase few line i can compile again, so i don't see errors in code, because same lcdout "xxxxxxxxxxx" line if i use up then few time i get this error
    6232 byte used, is it possible that I've spend all flash ??, I think I couldn't because PIC18F4685 has 96K (49152 words 3328 ram 1024 ee)
    Attachment 6782
    what else could be wrong ? all .inc .bas are pointed to right processor...... ideas
    Default Re: Error[126] c:\PBP\PBPPIC14.LIB : Argument out of range (2054 not between 0 and 2
    Post the lines of code that you delete in order to make it compile.
    Mar 2005
    CROATIA
    ..I'm paste same line xxxxxxxxxxxxx n time, 3 time (until this argument is smaller than 1024) works, and after wont
    any line i tried lcdout "test test test" or any other.... same result after this 6xxx bytes
    Free_cycle:                                      ' when idle
    if !cntupflag and !cntdownflag then
       if !IdleCnt then
            ReadCODE  (PreAddrTable + Idleoffset),Idlefrom
            ReadCODE  (PreAddrTable + Idleoffset + 1),Idleto
    lcdout com,l1
            for a=Idlefrom to Idlefrom + 3
                ReadCODE  (PressetTable + a),IdleParams[a]
    b=IdleParams[a]
    lcdout # a,"_",# b,","                                                              ' copy of this line cause agument out of range error126 but same line on another place works, or if i erase something else (to make space) this works too
            next a
            offset = Idlefrom + 4 + (IdleCnt*6)           'my coments
            ReadCODE  (PressetTable + Offset),bd
            ReadCODE  (PressetTable + Offset+1),bc
            ReadCODE  (PressetTable + Offset+2),bb
            ReadCODE  (PressetTable + Offset+3),ba
            ReadCODE  (PressetTable + Offset+4),ch[32]
            ReadCODE  (PressetTable + Offset+5),ch[33]
    'hserout ["idle_from=",dec idlefrom," to=",dec idleto," offs=",dec offset,"|cnt=",dec idlecnt,13,10]
    'high led3
    pause 4*IdleParams[3]
    'low led3
    IF idleParams[0] > 50 THEN
       RISE = 5
       SWITCH = 1
        RISE = idleParams[0]
        SWITCH = 0
    mac file at 560 line (blued) is it normal that this piece of macro is in asm, aqua color ?
    whole macro code if means anithing
    	NOLIST
    ; PICBASIC PRO(TM) Compiler 2.60C, (c) 1998, 2011 microEngineering Labs, Inc. All Rights Reserved.
    LABEL?L macro Label
            RST?RP
        ifdef PM_USED
            LALL
    Label
            XALL
    Label
    AIN?BBB macro Bin, Bout, Bndx
    	MOVE?BA	Bndx
            addlw   low (Bout)
            movwf   FSR0L
    	movlw	(Bout) >> 8
    	clrf	FSR0H
    	addwfc	FSR0H, F
            MOVE?BB Bin, INDF0
    AIN?BBW macro Bin, Bout, Wndx
    	MOVE?WA	Wndx
            addlw   low (Bout)
            movwf   FSR0L
    	movlw	(Bout) >> 8
    	addwfc	(Wndx) + 1, W
    	movwf	FSR0H
            MOVE?BB Bin, INDF0
    AIN?CBB macro Cin, Bout, Bndx
    	MOVE?BA	Bndx
            addlw   low (Bout)
            movwf   FSR0L
    	movlw	(Bout) >> 8
    	clrf	FSR0H
    	addwfc	FSR0H, F
            MOVE?CB Cin, INDF0
    AIN?WBB macro Win, Bout, Bndx
    	MOVE?BA	Bndx
            addlw   low (Bout)
            movwf   FSR0L
    	movlw	(Bout) >> 8
    	clrf	FSR0H
    	addwfc	FSR0H, F
            MOVE?WB Win, INDF0
    AOUT?BBB macro Bin, Bndx, Bout
            MOVE?BA Bndx
            addlw   low (Bin)
            movwf   FSR0L
    	movlw	(Bin) >> 8
    	clrf	FSR0H
    	addwfc	FSR0H, F
            MOVE?BB INDF0, Bout
    ADD?BBB macro Bin1, Bin2, Bout
        if ((Bout) == (Bin1))
            MOVE?BA Bin2
            CHK?RP  Bin1
            addwf   Bin1, F
          if ((Bout) == (Bin2))
            MOVE?BA Bin1
            CHK?RP  Bin2
            addwf   Bin2, F
            MOVE?BA Bin1
            CHK?RP  Bin2
            addwf   Bin2, W
            MOVE?AB Bout
    ADD?BBW macro Bin1, Bin2, Wout
            MOVE?BA Bin1
            CHK?RP  Bin2
            addwf   Bin2, W
            MOVE?AW Wout
            rlcf    (Wout) + 1, F
    ADD?BCB macro Bin, Cin, Bout
        if ((Bout) == (Bin))
          if ((Cin) == 1)
            CHK?RP  Bout
            incf    Bout, F
            movlw   Cin
            CHK?RP  Bin
            addwf   Bin, F
          if ((Cin) == 1)
            CHK?RP  Bin
            incf    Bin, W
            MOVE?AB Bout
            movlw   Cin
            CHK?RP  Bin
            addwf   Bin, W
            MOVE?AB Bout
    ADD?BCW macro Bin, Cin, Wout
        if ((Cin) == 1)
    	CHK?RP	Bin
    	incf	Bin, W
            movlw   low (Cin)
            CHK?RP  Bin
            addwf   Bin, W
            MOVE?AW Wout
        if (((Cin) >> 8) == 0)
            rlcf    (Wout) + 1, F
            movlw   (Cin) >> 8
            addwfc  (Wout) + 1, F
    ADD?CBW macro Cin, Bin, Wout
        if ((Cin) == 1)
    	CHK?RP	Bin
    	incf	Bin, W
            movlw   low (Cin)
            CHK?RP  Bin
            addwf   Bin, W
            MOVE?AW Wout
            rlcf    (Wout) + 1, F
            movlw   (Cin) >> 8
    ADD?CWW macro Cin, Win, Wout
        if ((Wout) == (Win))
            CHK?RP  Wout
          if ((Cin) == 1)
            incf    Wout, F
            movlw   low (Cin)
            addwf   Wout, F
            movlw   (Cin) >> 8
            CHK?RP  Win
          if ((Cin) == 1)
            incf    Win, W
            movlw   low (Cin)
            addwf   Win, W
            MOVE?AB Wout
            movlw   (Cin) >> 8
            CHK?RP  Win
            addwfc  (Win) + 1, W
            MOVE?AB (Wout) + 1
    ADD?WCW macro Win, Cin, Wout
            CHK?RP  Wout
          if ((Cin) == 1)
            incf    Wout, F
            movlw   low (Cin)
            addwf   Wout, F
            movlw   (Cin) >> 8
            CHK?RP  Win
          if ((Cin) == 1)
            incf    Win, W
            movlw   low (Cin)
            addwf   Win, W
            MOVE?AB Wout
            movlw   (Cin) >> 8
            CHK?RP  Win
            addwfc  (Win) + 1, W
            MOVE?AB (Wout) + 1
    ADD?WWW macro Win1, Win2, Wout
        if ((Wout) == (Win1))
            MOVE?BA Win2
            CHK?RP  Wout
            addwf   Wout, F
            MOVE?BA (Win2) + 1
            CHK?RP  Wout
          if ((Wout) == (Win2))
            MOVE?BA Win1
            CHK?RP  Wout
            addwf   Wout, F
            MOVE?BA (Win1) + 1
            CHK?RP  Wout
            MOVE?BA Win1
            CHK?RP  Win2
            addwf   Win2, W
            MOVE?AB Wout
            MOVE?BA (Win1) + 1
            CHK?RP  Win2
            addwfc  (Win2) + 1, W
            MOVE?AB (Wout) + 1
    DIV?WCB macro Win, Cin, Bout
        if ((Cin) == 2)
            CHK?RP  Win
            rrcf    (Win) + 1, W
            rrcf    Win, W
            MOVE?AB Bout
            MOVE?WW Win, R0
            MOVE?CW Cin, R1
            L?CALL  DIV
            MOVE?AB Bout
    DIV_USED = 1
    MUL?BCW macro Bin, Cin, Wout
            MOVE?BW Bin, R3
            MOVE?CW Cin, R1
            L?CALL  MUL
            MOVE?AWW R2, Wout
    MUL_USED = 1
    MUL?CBW macro Cin, Bin, Wout
            MOVE?CW Cin, R3
            MOVE?BW Bin, R1
            L?CALL  MUL
            MOVE?AWW R2, Wout
    MUL_USED = 1
    SUB?BBW macro Bin1, Bin2, Wout
            MOVE?BA Bin2
            CHK?RP  Bin1
            subwf   Bin1, W
            MOVE?AW Wout
            btfss   STATUS, C
            decf    (Wout) + 1, F
    SUB?BCB macro Bin, Cin, Bout
          if ((Cin) == 1)
            CHK?RP  Bout
            decf    Bout, F
            movlw   Cin
            CHK?RP  Bout
            subwf   Bout, F
          if ((Cin) == 1)
            CHK?RP  Bin
            decf    Bin, W
            movlw   Cin
            CHK?RP  Bin
            subwf   Bin, W
            MOVE?AB Bout
    AND?BCB macro Bin, Cin, Bout
        if (Bout == Bin)
            movlw   Cin
            CHK?RP  Bin
            andwf   Bin, F
            movlw   Cin
            CHK?RP  Bin
            andwf   Bin, W
            MOVE?AB Bout
    AND?BWW macro Bin, Win, Wout
        if (Wout == Win)
            MOVE?BA Bin
            CHK?RP  Wout
            andwf   Wout, F
            clrf    Wout + 1
            MOVE?BA Bin
            CHK?RP  Win
            andwf   Win, W
            MOVE?AW Wout
    LAND?BBW macro Bin1, Bin2, Wout
            MOVE?BB Bin1, R0
            MOVE?BA Bin2
            L?CALL  LAND
            MOVE?AB Wout
            movwf   Wout + 1
    LAND_USED = 1
    LAND?TBW macro Regin, Bitin, Bin, Wout
            MOVE?TB Regin, Bitin, R0
            MOVE?BA Bin
            L?CALL  LAND
            MOVE?AB Wout
            movwf   Wout + 1
    LAND_USED = 1
    LNOT?TB macro Regin, Bitin, Bout
            CHK?RP  Regin
            clrf    WREG
            btfss   Regin, Bitin
            movlw   -1
            MOVE?AB Bout
    CMPT?BL macro Bin, Label
            CLRWDT?
            MOVE?BA Bin
            BIT?GOTO 0, STATUS, Z, Label
    CMPT?TL macro Regin, Bitin, Label
            CLRWDT?
            BIT?GOTO 1, Regin, Bitin, Label
    CMPF?TL macro Regin, Bitin, Label
            CLRWDT?
            BIT?GOTO 0, Regin, Bitin, Label
    CMPF?WL macro Win, Label
            CLRWDT?
            MOVE?BA Win
            iorwf   (Win) + 1, W
            BIT?GOTO 1, STATUS, Z, Label
    CMPGE?BBL macro Bin1, Bin2, Label
            CLRWDT?
            MOVE?BA Bin2
            CHK?RP  Bin1
            subwf   Bin1, W
            BIT?GOTO 1, STATUS, C, Label
    CMPGT?BCL macro Bin, Cin, Label
        if ((Cin) < 0)
            L?GOTO  Label
          if ((Cin) < 0ffh)
            CLRWDT?
            MOVE?CA (Cin) + 1
            CHK?RP  Bin
            subwf   Bin, W
    CMPGT?BWL macro Bin, Win, Label
            MOVE?BW Bin, R0
            MOVE?WWA Win, R1
            L?CALL  CMPGT
    CMPGT_USED = 1
    CMPLE?BBL macro Bin1, Bin2, Label
            CLRWDT?
            MOVE?BA Bin1
            CHK?RP  Bin2
            subwf   Bin2, W
    CMPLE?BCL macro Bin, Cin, Label
        if ((Cin) >= 0ffh)
            L?GOTO  Label
          if ((Cin) >= 0)
            CLRWDT?
            MOVE?CA (Cin) + 1
            CHK?RP  Bin
            subwf   Bin, W
            BIT?GOTO 0, STATUS, C, Label
    CMPLT?BBL macro Bin1, Bin2, Label
            CLRWDT?
            MOVE?BA Bin2
            CHK?RP  Bin1
            subwf   Bin1, W
    CMPLT?BCL macro Bin, Cin, Label
        if ((Cin) >= 100h)
            L?GOTO  Label
          if ((Cin) > 0)
            CLRWDT?
            MOVE?CA Cin
            CHK?RP  Bin
            subwf   Bin, W
    CMPNE?BCL macro Bin, Cin, Label
        if (((Cin) > -100h) & ((Cin) < 100h))
            CLRWDT?
            MOVE?BA Bin
            sublw   Cin
            L?GOTO  Label
    CMPNE?TCL macro Regin, Bitin, Cin, Label
        if ((Cin) == 0)
            CLRWDT?
          if ((Cin) == 1)
            CLRWDT?
            L?GOTO  Label
    SHIFTL?BCB macro Bin, Cin, Bout
        if ((Cin) == 1)
            bcf     STATUS, C
            CHK?RP  Bout
            rlcf    Bout, F
            CHK?RP  Bin
            rlcf    Bin, W
            MOVE?AB Bout
            MOVE?BB Bin, R0
            movlw   Cin
            L?CALL  SHIFTL
            MOVE?AB Bout
    SHIFTL_USED = 1
    SHIFTL?CBW macro Cin, Bin, Wout
            MOVE?CW Cin, R0
            MOVE?BA Bin
            L?CALL  SHIFTL
            MOVE?AWW R0, Wout
    SHIFTL_USED = 1
    SHIFTL?WCW macro Win, Cin, Wout
        if ((Cin) == 1)
            bcf     STATUS, C
            CHK?RP  Wout
            rlcf    Wout, F
            rlcf    Wout + 1, F
            CHK?RP  Win
            rlcf    Win, W
            MOVE?AB Wout
            CHK?RP  Win
            rlcf    Win + 1, W
            MOVE?AB Wout + 1
            MOVE?WW Win, R0
            movlw   Cin
            L?CALL  SHIFTL
            MOVE?AWW R0, Wout
    SHIFTL_USED = 1
    SHIFTR?CBW macro Cin, Bin, Wout
            MOVE?CW Cin, R0
            MOVE?BA Bin
            L?CALL  SHIFTR
            MOVE?AWW R0, Wout
    SHIFTR_USED = 1
    ASM? macro
            RST?RP
    BRANCH?BCL macro Bin, Cin, Label
        local jmptbl
    	MOVE?BA	Bin
    	movwf	R0
    	sublw	(Cin) - 1
    	clrf	PCLATH
    	clrf	PCLATU
    	rlcf	R0, F
    	rlcf	PCLATH, F
    	movlw	low (jmptbl)
    	addwf	R0, F
    	movlw	high (jmptbl)
    	addwfc	PCLATH, F
    	movlw	upper (jmptbl)
    	addwfc	PCLATU, F
    	movf	R0, W
    	movwf	PCL
    jmptbl
    BRGOTO?L macro Label
            bra     Label
    CLEAR? macro
        local loop
          ifdef USE_LFSR
            lfsr    0, RAM_END
    	MOVE?CW	RAM_END, FSR0L
    loop    clrf    POSTDEC0
            movf    FSR0L, W
            iorwf   FSR0H, W
            bnz     loop
            clrf    INDF0
    CLEAR_USED = 1
    DDISABLE? macro
    DENABLE? macro
    END? macro
        local loop
    loop    sleep
            L?GOTO  loop
    ENDASM? macro
    GOSUB?L macro Label
        local dlabel
        ifdef DEBUG_STACK
            CHK?RP  DEBUG_STACK
          ifdef DEBUG_STACK_ADDR
            bcf     STATUS, C
            rlcf    DEBUG_STACK, W
            addlw   DEBUG_STACK_ADDR
            movwf   FSR0L
            clrf    FSR0H
            movlw   low (dlabel)
            movwf   POSTINC0
            movlw   high (dlabel)
            movwf   INDF0
            incf    DEBUG_STACK, F
            L?CALL  Label
    dlabel
    GOTO?L macro Label
            L?GOTO  Label
    HIGH?T macro Regin, Bitin
            MOVE?CT 1, Regin, Bitin
            MOVE?CT 0, ((Regin) + 12h), Bitin
    LCDOUT?C macro Cin
            movlw   Cin
            L?CALL  LCDOUT
    LCDOUT_USED = 1
    LCDOUTD?B macro Bin
            MOVE?BA Bin
            L?CALL  LCDOUTDEC
    LCDOUTDEC_USED = 1
    LCDOUTCOUNT?C macro Cin
            MOVE?CB Cin, R4 + 1
    LCDOUTNUM?B macro Bin
            MOVE?BW Bin, R2
    LCDOUTBIN? macro
            MOVE?CW LCDOUTJ, R8
            L?CALL  SEROUT2BIN
    LCDOUTJ_USED = 1
    SEROUT2BIN_USED = 1
    LCDOUTDEC? macro
            MOVE?CW LCDOUTJ, R8
            L?CALL  SEROUT2DEC
    LCDOUTJ_USED = 1
    SEROUT2DEC_USED = 1
    LOW?T macro Regin, Bitin
            MOVE?CT 0, Regin, Bitin
    NEXT?BCL macro Bin, Cin, Label
        if ((Cin) == 1)
            CHK?RP  Bin
            incf    Bin, F
            movlw	Cin
            CHK?RP  Bin
            addwf   Bin, F
        if ((Cin) <= 255)
    PAUSE?C macro Cin
            MOVE?CA Cin
            L?CALL  PAUSE
            MOVE?CB (Cin) >> 8, R1 + 1
            MOVE?CA low (Cin)
            L?CALL  PAUSEL
    PAUSE_USED = 1
    PAUSE?W macro Win
            MOVE?WWA Win, R1
            L?CALL  PAUSEL
    PAUSE_USED = 1
    PAUSEUS?C macro Cin
            movlw   Cin
            L?CALL  PAUSEUS
            MOVE?CB (Cin) >> 8, R0 + 1
            MOVE?CA low (Cin)
            L?CALL  PAUSEUSL
    PAUSEUS_USED = 1
    READCODE?WB macro Win, Bout
    	MOVE?WW	Win, TBLPTRL
    	L?CALL	READCODE
            MOVE?AB Bout
    READCODE_USED = 1
    READCODE?WW macro Win, Wout
    	L?CALL	READCODE
            MOVE?AB Wout
    	MOVE?BB	TABLAT, Wout + 1
    READCODEW_USED = 1
    RETURN? macro
        ifdef DEBUG_STACK
            CHK?RP  DEBUG_STACK
            decf    DEBUG_STACK, F
            RST?RP
    TOGGLE?T macro Regin, Bitin
            BIT?FLIP Regin, Bitin
    	LIST
    Mar 2005
    CROATIA
    I have messing around this macro and line to which points this error126 (560)
    and it shows on
    local jmptbl
    MOVE?BA Bin
    movwf R0
    sublw (Cin) - 1
    branch ?? .... so i was remarked branch line and error126 has disappear
    ok I must use select case-goto instead, but now i tried putting
    dummy 200 lines of
    which increased hex for 3 times, but compiles correctly,
    so obvious there is some bug with branch keyword after code grows.....
    something like jump address can't be bigger then xxxx word....
    but i don't know much about macros and internals, so I'm happy to bound this bug
    Sep 2009
    It's not a bug, it's a feature
    From manual:
    Label must be in the same code page as the BRANCH instruction.
    If you want to go out of page you must use BRANCHL.
    But its twice bigger than BRANCH.
    Mar 2005
    CROATIA
    yes, tried with branchl works like a charm....
    it's really overkill feature, night killer, but ok,
    da nas dvojca moramo do ovamo poteč da riješimo bubu :P
    so, error126 explicitly means that you are using branch out of page ?
    maybe somewhere exist kind of RFM for errors ? this could save time too...
    thank you for help
