How to use UC2638
Results 1 to 5 of 5
    seinfield's Avatar
    seinfield Guest
    Default How to use UC2638
    Hi, i am making a little robot, i finished the 6 ultrasonic distance sensors, but now i am designing the motor control.
    I founded this IC: UC2638 from TI, but does someone knows how it works?.
    How can i turn a motor to the other side?
    I am using servo motors.
    Gilberto
    Mexico.
    Smile
    Hi,Gilberto
    Did you find the datasheet ???
    http://www.alldatasheet.com ...
    It's basically a Voltage to PWM converter ...
    seinfield's Avatar
    seinfield Guest
    Thanks, i know that it is a voltage to PWM coverter;
    But how i know to move the motor in other direction?
    A quick look at the internal scheme or a reading of the datasheet could have shown you that:
    INput = VCC > Max Forward
    = AREFIN > stop
    = VEE > Max Reverse
    ... fig 2 is very explicit about that !!!
    Good night
    seinfield's Avatar
    seinfield Guest
    Thanks, i missed that.
    Upps, sorry, i read the datasheet at night and i was sleepy, now i understand!
    Thanks!
