Cooking Timer Project
Results 1 to 14 of 14
    Nov 2010
    Thank you for replying back. This is the LCD that I have
    http://www.parallax.com/Store/Access...0/Default.aspx
    Try a baud mode number of 16780, I think this things are inverted.
    SW1 = ON
    SW2 = OFF
    Nov 2010
    SW1 = ON
    SW2 = OFF
    I will try that. And also this is my first time dealing with pics I have a question also about my set up does it need power to run to the pic? if so what leg its a pic16F819
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by esmore View Post
    Err yes you need to supply power to the PIC to run it !
    5vdc required
    Have a read of the data sheet http://oap.sourceforge.net/datasheets/PIC16F819.pdf
    Nov 2010
    Quote Originally Posted by malc-c View Post
    5vdc required
    I look at the diagram pin 14 VDD is my 5volts so does that make pin 5 VSS the ground?
    Thank you for the data sheet
    malc-c's Avatar
    malc-c Guest
    Yes - Vss should go to GND and Vdd to +5v Without these connections your PIC won't run !
    Also look in the manual, section "2.4. It=s Alive".
    This shows the basic/generic setup required. VDD, VSS, MCLR, OSC...
