What commands reset the WDT?
Results 1 to 4 of 4
    Here is some info on the WDT from the manual.
    The Watchdog Timer is used in conjunction with the SLEEP and NAP
    instructions to wake the PIC MCU after a certain period of time.
    Assembler instructions (clrwdt) to keep the Watchdog Timer from timing
    out under normal circumstances and resetting the PIC MCU are
    automatically inserted at appropriate places throughout the program.
    CLEARWDT allows the placement of additional clrwdt instructions in the
    program.
    The Watchdog Timer is enabled by PBP. It is used, along with the TMR0
    prescaler, to support the NAP and SLEEP instructions. If neither of the
    instructions are used in a program, the Watchdog Timer may be disabled
    and the prescaler used for something else.
    If you want to tell PBP not to automatically insert the clrwdt instructions, you can use this define, and insert them yourself.
    DEFINE NO_CLRWDT 1 ‘ Don’t insert CLRWDTs
    But if you don't want to use it at all, you must turn it off in the configs.
    http://www.scalerobotics.com
    Nov 2010
    Thanks for the information, this clears up a lot of issues
    Nov 2010
    Another question: When/where does it decide to place these clears in the code? Im looking through the .asm file and I cannot find anything that looks like it.
