weird problem with dot matrix and shift register
Results 1 to 6 of 6
    Oct 2009
    Default weird problem with dot matrix and shift register
    Hi everyone,
    I m trying to drive 8x8 dot matrix and i m facing a weird problem.
    when i try to display simple pattern like this
    i got
    if you notice, the third and eight rows is supposed to be OFF but they are not. instead, they are ON with a little brightness than the second and the seventh ( ON rows )
    i tried to figure out whats the problem. is there any reason that the shift register used to sink column currents isnt able to change its state instantly from logic 1 to logic 0 ? is there some capacitance related to its latch function ?
    ** i used hef4094 to sink columns current and it receives its data serially from PIC16f84
    ** i used 8 transistors to source current to rows. they are connected to portb
    this is the code i used
    INCLUDE "MODEDEFS.BAS"
    TRISB = 0
    TRISA = 0
    SYMBOL  STRB  = PORTA.0
    SYMBOL  DAT   = PORTA.1
    SYMBOL  CLK   = PORTA.2
    SYMBOL  EN    = PORTA.3
    TEMP    VAR BYTE
    CNTR1   VAR BYTE
    CNTR2   VAR BYTE
    COL     VAR BYTE
    ROW     VAR BYTE
    COLVAR  VAR BYTE[8]
    ROWVAR  VAR BYTE[8]
    PORTB = 0
    PORTA = 0
    CNTR1 = 0
    CNTR2 = 0
    EN = 1
    start:
    COLVAR[0] = %11000000:COLVAR[1]=%11000000:COLVAR[2]=0:COLVAR[3]=0
    COLVAR[4] = 0:COLVAR[5] = 0:COLVAR[6] = %11000000:COLVAR[7] = 0
    MAIN:
    FOR CNTR2 = 0 TO 100
    PORTB = 1
    FOR CNTR1 = 0 TO 7
     STRB = 0
     COL = COLVAR[CNTR1]^255
    SHIFTOUT DAT,CLK,0,[COL]
    STRB = 1
    PAUSE 2
    PORTB = PORTB *2
    NEXT CNTR1
    NEXT CNTR2
    'FOR CNTR1 = 0 TO 7
    'COLVAR[CNTR1] = COLVAR[CNTR1]<<1
    'NEXT CNTR1
    GOTO MAIN
    Oct 2009
    Cool
    to summerize the problem here is what is happening
    * i m loading column data to shift register then latch it
    * i m scanning the rows each for 1 ms
    * when moving from a row that has a pattern e.g. (11000000) to the next row with
    pattern ( 00 00 00 00 ) , the bits that were at logic 1 in the previous state dont turn off to logic zero!! instead they are in intermediate state ( i.e. maybe 2.5 volts instead of zero)
    so they still ON but with little brightness
    this problem happens whenever a bit is turned of in the next scan ( i.e. whenever a bit that was 1 turned to be 0 in the next row)
    thats weird.
    I think you just need to "Blank" the rows before changing the Column data, then turn the next row on.
    Try it like this ...
      FOR CNTR1 = 0 TO 7
        STRB = 0
        PORTB = 0                   ; blank all Rows
        STRB = 1                    ; latch the data
        PORTB = DCD CNTR1           ; turn on next Row
        PAUSE 2
      NEXT CNTR1
    NEXT CNTR2
    Oct 2009
    Smile worked !!
    Darrel,
    thx alot for helping, it worked really well.
    i always wished to thank you in person. cuz from 3 years i enter this forum as a visitor and i always see ur post. you always find the solution. thx much Darrel.
    still i have a problem i didnt mention. the first row always doesnt give full brightness when it is on. i suppose this relates to the previous problem. i will try to work it out.
    thx again Darrel.
    BW
    Thanks Ahmadabuomar, and your welcome.
    First row's dimmer than the others ... ok.
    Let's try moving the "blanking", so that all the rows are ON the same amount of time.
    It should actually dim the other 7 rows to what the first one was.
      FOR CNTR1 = 0 TO 7
        STRB = 0
        PORTB = DCD CNTR1           ; turn on the Row
        PAUSE 2                     ; LED ON time
      NEXT CNTR1
    NEXT CNTR2
    Oct 2009
    Thumbs up solved it
    Hi Darrel,
    in fact, row 1 problem was not related to software!! after i tried your last code. i found nothing changed.
    I then checked all npn transistors used in rows. i found the transistor on portb.0 is not working properly !! i changed the transistor and the problem was solved.
    all portb transistors were bc337 25 npn transistors except portb.0 that was bc337 40
    i dont know if 40 is different than 25 !! but i think the transistor itself is not working
    thx Darrel for your help
    BW
