Hello Unregistered ,
Did you set the OSCCON register? Otherwise it will default to 1 mhz (x4 pll) = 4 mhz.
http://www.scalerobotics.com
Originally Posted by scalerobotics Did you set the OSCCON register? Otherwise it will default to 1 mhz (x4 pll) = 4 mhz. I didn't do that setting before. I did it now and everything works fine now. Thank you so much for your help.
View Tag Cloud
Forum Rules
