l_gaminde,
For a Label, do the following,
Set the Multiline property of the label object to true. Also, make the scrollbars visible if you want to. End your command line with & vbcrlf like in the code that you posted
label1.Caption = byte1 & byte2 & byte3 & vbcrlf
For a Textbox, do the following,
  • Set Multiline to true
  • Set ReadOnly to true
  • Write your code like the following
textbox1.text = byte1 & byte2 & byte3 & VbCrLf             'This is the first line
textbox1.AppendText(byte1 & byte2 & byte3 & VbCrLf)   'These are the following lines
I'm not in front of my personal PC, so I haven't tested this code but it should work. Let me know if you have problems.
Ok i tried the second part and it will not compile method or data member not found
and thats the Appendtext
