l_gaminde,
For a Label, do the following,
Set the Multiline property of the label object to true. Also, make the scrollbars visible if you want to. End your command line with & vbcrlf like in the code that you posted
label1.Caption = byte1 & byte2 & byte3 & vbcrlf
For a Textbox, do the following,
  • Set Multiline to true
  • Set ReadOnly to true
  • Write your code like the following
textbox1.text = byte1 & byte2 & byte3 & VbCrLf             'This is the first line
textbox1.AppendText(byte1 & byte2 & byte3 & VbCrLf)   'These are the following lines
I'm not in front of my personal PC, so I haven't tested this code but it should work. Let me know if you have problems.
ok the first one doesn't work, thats what I have been wondering about it sits on line one and changes per each set of inputs and never drops down vbcrlf chr(10) or 13 nothing works on the end of the line ?? works in the middle like your test but not at the end.
I will try the append thing now it will not read the first line textbox1.text again because I may have 30 to 100 or more lines to download
