VB5 to Pic VB5 Help
Results 1 to 21 of 21
    Aug 2009
    Paso Robles California
    Default VB5 to Pic VB5 Help
    Im working on a VB5 to pic project, I need some help with a text box. Im unable to scroll data to this box using multiline and scroll bar, vbCrLf does not work chr(13) & chr(10) nothing works. if I put the vbCrLf as the first item on the line it drops down one line and prints all input on that line instead of scrolling.
    This is time and date data from the pic and a 1307 rtc. I am able to scroll into a picture box using print. I have tried to break each byte out used the string, used formatting it all works in the picture window but scrolls off page, picture windows do not have scroll bars so some data gets lost.
    Miami, Florida USA
    Post your VB5 code and I might be able to tell you what is wrong.
    Note: This is probably a wrong forum section to ask VB5 questions.
    Anonymous
    Aug 2009
    Default Pic to VB5
    Yes on the wrong forum it is data from a Pic
    Text1.Text = byte1 & byte2 & byte3
    adding vbcrlf or chr(13) or chr(10) has no effect on text box
    if I do
    text1.text = " I feel like " vbcrlf will go to the next line
    but variables will not
    Miami, Florida USA
    Quote Originally Posted by l_gaminde View Post
    if I do
    Try it like this
    Text1.Text = byte1 & vbcrlf & byte2 & vbcrlf & byte3
    Anonymous
    Aug 2009
    Default vb5
    no it will not work with a variable
    this is what I see from this
    Text1.Text = mystr & vbCrLf & mystr & vbCrLf
    88"88 88/88||88:88 88/88||
    but when i copy and paste I get below it pastes with cr lf
    This is really odd
    88:88 88/88
    88:88 88/88
    The double lines are thicker I do not see them on my ansi chart
    Miami, Florida USA
    I use VB6, but I am not familiar with VB5. However, they should be more or less the same.
    Try a Label box instead of a Text box. The following code works fine for me, because I just took it from one of my working VB6 programs.
    Label1.Caption = byte1 & vbcrlf & byte2 & vbcrlf & byte3
    If you still insist in using a Text box, then the following might help you. This quote is taken from a VB6 help file.
    To display multiple lines of text in a TextBox control, set the MultiLine property to True. If a multiple-line TextBox doesn't have a horizontal scroll bar, text wraps automatically even when the TextBox is resized. To customize the scroll bar combination on a TextBox, set the ScrollBars property.
    Scroll bars will always appear on the TextBox when its MultiLine property is set to True, and its ScrollBars property is set to anything except None (0).
    If you set the MultiLine property to True, you can use the Alignment property to set the alignment of text within the TextBox. The text is left-justified by default. If the MultiLine property is False, setting the Alignment property has no effect.
    Anonymous
    Aug 2009
    Default Pic to VB5
    Ok some of this worked and some did not I will be working on this again next week.
    I have not given up just had problems (KIDS) thanks and will post more next week
    Aug 2009
    Default vb5 to Pic
    I tried your example and it worked but try this and let me know if it works for you
    label1.Caption = byte1 & byte2 & byte3 & vbcrlf
    now go through this 5 times and see if it goes to the next line or stays on one line
    Miami, Florida USA
    It stays on one line. Remember you are changing the caption of the label object.
    Anonymous
    Aug 2009
    Default vb5 to pic
    Robert No I don't understand what your saying changing the caption Im lost
    I want byte1 byte2 and byte3 on one line, then the next line down the same thing this is serial data so byte1-3 are different values on each line, there just being used for formatting a string value so the layout is simple and easy.
    Miami, Florida USA
    l_gaminde,
    For a Label, do the following,
    Set the Multiline property of the label object to true. Also, make the scrollbars visible if you want to. End your command line with & vbcrlf like in the code that you posted
    For a Textbox, do the following,
    • Set Multiline to true
    • Set ReadOnly to true
    • Write your code like the following
    textbox1.text = byte1 & byte2 & byte3 & VbCrLf             'This is the first line
    textbox1.AppendText(byte1 & byte2 & byte3 & VbCrLf)   'These are the following lines
    I'm not in front of my personal PC, so I haven't tested this code but it should work. Let me know if you have problems.
    Anonymous
    Aug 2009
    Default vb5
    l_gaminde,
    ok the first one doesn't work, thats what I have been wondering about it sits on line one and changes per each set of inputs and never drops down vbcrlf chr(10) or 13 nothing works on the end of the line ?? works in the middle like your test but not at the end.
    I will try the append thing now it will not read the first line textbox1.text again because I may have 30 to 100 or more lines to download
    Aug 2009
    Default vb5
    l_gaminde,
    Ok i tried the second part and it will not compile method or data member not found
    and thats the Appendtext
    Aug 2009
    Default vb5
    l_gaminde,
    one more thing I have changed the byte1 -3 and its now mystr which is all formatted
    Aug 2009
    Default vb5
    this is what my data looks like
    Name:  New Picture.bmp
    Miami, Florida USA
    L_gaminde,
    The next code works fine because I just tested it with VB6 in my PC. I expect that it should work for you too with your VB5 version.
    - Create a textbox
    - Set multiline to true
    - Set scrollbars to "3 - both"
    - Use the following code
    Text1.text = Byte1 & vbCrLf    'This is the first line
    Text1.SelStart = Len(Text1)    'Finds the starting point to append text
    Text1.SelText = Byte2 & vbCrLf   'Appends text
    Text1.SelText = Byte3 & vbCrLf   'Appends text
    Use the code for the first line only once if you want the results to keep scrolling.
    Edit: The code I gave you in a previous post works for VB.net. Wrong version .
    Anonymous
    Aug 2009
    Default VB5 2 Pic
    This is what I tried
    Text1.SelText = mystr & vbCrLf 'Appends text
    This is what I get!! two lines that both lines change as data comes in.
    88:88 88/88
    88:88 88/88
    Miami, Florida USA
    Like I said before, use the first line of code only once. Use the other two lines of code for the rest of the incomming data.
    Using the first line again and again will "reset" the text in your textbox. If you need help post all your code. This code works fine because I tested it.
    Anonymous
    Aug 2009
    Default vb5
    I don't understand, I only used the first line once. I have one formatted variable mystr! Im getting this data through an oncomm when I get 9 bytes of data it fires and sets up my string sData, sData is then formatted into mystr, and mystr then sent to a file on disk and to a Picture box. I know if I have three lines it will print three lines!! I may have hundreds of lines so I really don't want to wirte 100 + text1.text lines, I want it to loop through the data as it comes in and put it on a line below the last. I have a counter running wonder if I can use the count value to tell the text box to drop one line and print can a text box be told which line to print on. This is basically a do loop where mystr is reloaded with new data each pass and then printed. Now when using the write or print commands with this data it works perfect but print and write do not work with a text box or lable box. Right now Im using to picture boxes when one fills up it goes on to the next but sometimes both fill up and I loose some data guess another picture box or two would help, bout could fill them also.
    Public Sub MSComm1_ONComm()
    If MSComm1.CommEvent = comEvReceive Then
    sData = MSComm1.Input
    cnt = cnt + 1
    cnt1 = Format(cnt, "0#")
    If Mid(sData, 1, 1) = "8" Then Command_End
    mystr = Format(sData, " 0#:## 0#/## ")
    FileNum = FreeFile ' Writes New Data To Disc (Named C:\Tracker)
    Open "C:\Tracker.txt" For Append As FileNum
    Print #FileNum, " "; cnt1 & " "; mystr
    Close FileNum
    If cnt <= 43 Then PicData1.Print " "; cnt1 & " "; mystr
    If cnt > 43 Then PicData2.Print " "; cnt1 & " "; mystr
    End If
    End Sub
    Miami, Florida USA
    Ok, I will make it even simpler. This is the code I'm using to test the multiline feature
    Option Explicit
    Private Sub Command1_Click()
    Dim MyNumber As Long
    Dim I As Long
    MyNumber = 0
    For I = 0 To 50
        Text1.SelText = MyNumber & vbCrLf       'Appends text
        MyNumber = MyNumber + 100
    Next I
    End Sub
    And, this is the result
    Just try these two lines and they should work
    Make sure you have the next settings correct
    Anonymous
    Aug 2009
    Default VB5 to Pic
    For Me Simple is really good!! THIS WORKS !! just changed the mynumber to mystr and bingo scrolls, Ok I just ( learnt somethin )
    Thank You !!
    you spent a lot of time helping! I appreciate it! there was someone else who could use this but forgot who ??
    Thank You
    Larry
