Degrees to decimal conversion
Results 1 to 4 of 4
    Default Degrees to decimal conversion
    Hi all
    I have a decimal readout from a device which is giving me
    a 16bit value (65535) for 1 resolution (360 deg)
    I want to enter serially degrees.xx and convert this to a 16 bit value and also to a 12bit value
    Decimal_value_16bit var word '(0-65535)
    Decimal_value_12bit var word '(0-4098)
    degrees var word '(0-360)
    degrees_fraction var byte '(.xx)
    serin2 rxd,84,[degrees,wait ".",degrees_fraction]
    Any idea how this can be done ? pse I dont want to use "longs"
    No longs? ... We don't need no stinking Longs ...
    But a little N-Bit_MATH will definitely help. http://www.picbasic.co.uk/forum/showthread.php?t=12433
    To go from decimal degrees to 16-bit binary it would take ...
    65535 * degrees / 35999
    If you were using an 18F with PBPL ... that's all you would need.
    But if you don't want LONGs, then ...
    65535 * anything bigger than 1 will take more than 16-bits.
    And since DIV32 is really DIV31/15 ... 35999 is too big for the divisor (max is 32767).
    So N-Bit_Math to the rescue.
    rxd                 var PORTC.7
    txd                 var PORTC.6
    HIGH txd
    degree_Total        var word
    '----[N-Bit Math]-----------------------------------------------------------
    PRECISION  CON 4 SYSTEM          ; 4 bytes=32-bit
    INCLUDE "N-Bit_MATH.pbp"
    Temp1   VAR BYTE[PRECISION]
    Temp2   VAR BYTE[PRECISION]
    '----[Main Program Loop]----------------------------------------------------
        serout2 txd,84,[13,10,"Enter Degrees (Max=359.99): "]
        serin2 rxd,84,[DEC degrees,DEC2 degrees_fraction]
        Degree_Total = degrees * 100 + degrees_fraction
          MOVE?WP  _degree_Total, _Temp1           ; copy degrees to a PVAR
          MOVE?CP  65535, _Temp2                   ; put multiplier in a PVAR
          MATH_MUL _Temp1, _Temp2, _Temp1          ; Temp1 = DEG * 65535
          MOVE?CP  35999, _Temp2
          MATH_DIV _Temp1, _Temp2, _Temp1          ; Temp1 = Temp1 / 35999 (16-bit result)
          MOVE?PP  _Temp1, _Temp2                  ; copy result to Temp2
          MATH_ROR _Temp2                          ; rotate right 4 times
          MATH_ROR _Temp2
          MATH_ROR _Temp2
          MATH_ROR _Temp2                          ; Temp2 is now 12-bits
          MOVE?PW  _Temp1, _Decimal_value_16bit    ; copy PVAR's to WORDs
          MOVE?PW  _Temp2, _Decimal_value_12bit
        serout2 txd,84,[13,10,"16-bit: ",HEX4 Decimal_value_16bit,"  ",DEC Decimal_value_16bit,13,10]
        serout2 txd,84,["12-bit: ",HEX4 Decimal_value_12bit,"  ",DEC Decimal_value_12bit,13,10]
    GOTO Main
    And here's some of the output from a 16F876A ...
    Hi Darrel,
    Thanks a lot this is working perfect
    Imagine if I would like to do the opposite
    so from a 10 or 12bit value (representing 1 revolution) to deg.xx
    Can you put me on the right tracks to do that ?
    Decimal_value_10bit var word '(0-1024)
    Quote Originally Posted by RFsolution View Post
    It's essentially the same thing, with the order of the formula reversed.
    Originally for degrees to 16-bit we had ...
    65536 * degrees / 36000 (notice I've changed the constants)
    The reverse would be ...
    16-bit * 36000 / 65536
    You can change between any of the scales by simply changing the order and the constants.
    degrees to 12-bit ... degrees * 4096 / 36000
    12-bit to degrees ... 12-bit * 36000 / 4096
    degrees to 10-bit ... degrees * 1024/ 36000
    10-bit to degrees ... 10-bit * 36000 / 1024
    Here's a macro for N-Bit_Math that will let you do it easily ...
    Convert  macro WFrom, Frange, WTo, Trange
        MOVE?WP   WFrom,  _Temp1              ; copy From value to Temp1 Pvar
        MOVE?CP   Frange, _Range1             ; put From Range in Range1 Pvar
        MOVE?CP   Trange, _Range2             ; put To range in Range2
        MATH_MUL  _Temp1, _Range2, _Temp1     ; Temp1 = From * To_Range
        MATH_DIV  _Temp1, _Range1, _Temp1     ; Temp1 = Temp1 / From_Range
        MOVE?PW   _Temp1, WTo                 ; copy result to word variable WTo
    Then you can convert any of the scales to any other scale by providing the macro the From value with the "range" that variable goes to, a variable to put the result in and the range that variable should span.
    To convert the original degrees to 16-bit, you would ...
    @   Convert _degree_Total, 36000, _Decimal_value_16bit, 65536
    or to 12-bit ...
    @   Convert _degree_Total, 36000, _Decimal_value_12bit, 4096
    Going the other way is just as easy.
    @   Convert _Decimal_value_16bit, 65536, _degree_Total, 36000
    @   Convert _Decimal_value_12bit,  4096, _degree_Total, 36000
    Here's a test program ...
    <font color="#000000">rxd                 <b>VAR </b>PORTC.7
    txd                 <b>VAR </b>PORTC.6
    <b>HIGH </b>txd
    Decimal_value_16bit <b>VAR WORD </b><font color="#000080"><i>'(0-65535)
    </i></font>Decimal_value_12bit <b>VAR WORD </b><font color="#000080"><i>'(0-4095)
    </i></font>degrees             <b>VAR WORD </b><font color="#000080"><i>'(0-359)
    </i></font>degrees_fraction    <b>VAR BYTE </b><font color="#000080"><i>'(.xx)
    </i></font>degree_Total        <b>VAR WORD
    </b><font color="#000080"><i>'----[N-Bit Math]---------------------------------------------------------------
    </i></font>PRECISION  <b>CON </b>4 SYSTEM          <font color="#000080"><i>; 4 bytes=32-bit
    </i></font><b>INCLUDE </b><font color="#FF0000">&quot;N-Bit_MATH.pbp&quot;
    </font>Temp1    <b>VAR BYTE</b>[PRECISION]
    Range1   <b>VAR BYTE</b>[PRECISION]
    Range2   <b>VAR BYTE</b>[PRECISION]
    <b>ASM
    </b><font color="#008000">Convert  macro WFrom, Frange, WTo, Trange
        MOVE?WP   WFrom,  _Temp1              </font><font color="#000080"><i>; copy From value to Temp1 Pvar
        </i></font><font color="#008000">MOVE?CP   Frange, _Range1             </font><font color="#000080"><i>; put From Range in Range1 Pvar
        </i></font><font color="#008000">MOVE?CP   Trange, _Range2             </font><font color="#000080"><i>; put To range in Range2
        </i></font><font color="#008000">MATH_MUL  _Temp1, _Range2, _Temp1     </font><font color="#000080"><i>; Temp1 = From * To_Range
        </i></font><font color="#008000">MATH_DIV  _Temp1, _Range1, _Temp1     </font><font color="#000080"><i>; Temp1 = Temp1 / From_Range
        </i></font><font color="#008000">MOVE?PW   _Temp1, WTo                 </font><font color="#000080"><i>; copy result to word variable WTo
      </i></font><font color="#008000">endm
    </font><b>ENDASM
    </b><font color="#000080"><i>'----[Main Program Loop]--------------------------------------------------------
    </i></font>Main:
        <b>SEROUT2 </b>txd,84,[13,10,<font color="#FF0000">&quot;Enter Degrees (Max=359.99): &quot;</font>]
        <b>SERIN2 </b>rxd,84,[<b>DEC </b>degrees,<b>DEC2 </b>degrees_fraction]
        <font color="#000080"><i>;--- degrees to 16-bit ---
    </i></font><font color="#008000">@   Convert _degree_Total, 36000, _Decimal_value_16bit, 65536
        </font><b>SEROUT2 </b>txd,84,[13,10,<font color="#FF0000">&quot;16-bit: &quot;</font>,<b>HEX4 </b>Decimal_value_16bit,<font color="#FF0000">&quot;  &quot;</font>,<b>DEC </b>Decimal_value_16bit,13,10]
        <font color="#000080"><i>;--- degrees to 12-bit ---
    </i></font><font color="#008000">@   Convert _degree_Total, 36000, _Decimal_value_12bit, 4096
        </font><b>SEROUT2 </b>txd,84,[<font color="#FF0000">&quot;12-bit: &quot;</font>,<b>HEX4 </b>Decimal_value_12bit,<font color="#FF0000">&quot;  &quot;</font>,<b>DEC </b>Decimal_value_12bit,13,10]
        <font color="#000080"><i>;--- 16-bit to degrees ---
    </i></font><font color="#008000">@   Convert _Decimal_value_16bit, 65536, _degree_Total, 36000
        </font><b>SEROUT2 </b>txd,84,[<font color="#FF0000">&quot;Deg from 16-bit: &quot;</font>,<b>DEC </b>degree_Total/100,<font color="#FF0000">&quot;.&quot;</font>,<b>DEC2 </b>degree_Total,13,10]
        <font color="#000080"><i>;--- 12-bit to degrees ---
    </i></font><font color="#008000">@   Convert _Decimal_value_12bit, 4096, _degree_Total, 36000
        </font><b>SEROUT2 </b>txd,84,[<font color="#FF0000">&quot;Deg from 12-bit: &quot;</font>,<b>DEC </b>degree_Total/100,<font color="#FF0000">&quot;.&quot;</font>,<b>DEC2 </b>degree_Total,13,10]
    <b>GOTO </b>Main
    And here's some output from the test program ...
