Sd card code
Results 1 to 18 of 18
Thread: Sd card code
    May 2010
    Default Sd card code
    i would like to request code using pic basic for sd card reader......
    May 2010
    Smile sd card reader
    thanks....
    May 2010
    Default sd card reader
    can i request for sd card reader code in PBP version 2.6??
    As far as I can see the code I linked to previously IS for v2.6 - at least that's what it says, second line of code:
    'Name        : sdfs3.pbp
    'Compiler    : PICBASIC PRO Compiler 2.6 (PBPL only)
    'Assembler   : MPASM
    'Target PIC  : PIC16F4550
    <table style="width: 141px; height: 21px;"><tbody><tr><td class="number">
    </td><td class="content">
    </td></tr></tbody></table>
    May 2010
    sorry..it's my bad..it's PBP 2.5 version that i used...
    thanks..
    The link provided works for 2.5 also. PBPL is the key.
    May 2010
    Thumbs up sd card reader
    thanks....
    does this also support SDHC cards?
    SDFS was modified for FAT32 and can be found here
    http://www.picbasic.co.uk/forum/show...7887#post77887
    It works for me as is but is not being maintained.
    May 2010
    i have try to compile the source code that you gave, but there are a lot of error...one of them are Redefinition of LABEL SD_CS.i would like to know what are the meaning of this error?? i have google but it not helping....
    thanks
    Looks like you tried compiling SDFS.BAS as a stand alone, it is an "include".
    Did you read "sdreadme.txt"?
    Did you write any code to use the include? If so, post it.
    May 2010
    this is the code....
        Define    OSC    20    ' 20 MHz oscillator
    ' Alias PIC pins and registers for SD/MMC card
    SD_WE        Var    PORTA.4    ' SD card write protect
    SD_WE_TRIS    Var    TRISA.4    ' SD card write protect direction
    SDI        Var    PORTB.0    ' SPI data in
    SDI_TRIS    Var    TRISB.0    ' SPI data in direction
    SCL        Var    PORTB.1    ' SPI clock
    SCL_TRIS    Var    TRISB.1    ' SPI clock direction
    SD_CS        Var    PORTB.3    ' SD card chip select
    SD_CS_TRIS    Var    TRISB.3    ' SD card chip select direction
    SD_CD        Var    PORTB.4    ' SD card detect
    SD_CD_TRIS    Var    TRISB.4    ' SD card detect direction
    SDO        Var    PORTC.7    ' SPI data out
    SDO_TRIS    Var    TRISC.7    ' SPI data out direction
    ' Include the SD/MMC subroutines (found in http://melabs.com/resources/samples/pbp/sdfs3.zip)
        Include "SDFS.PBP"
        SDC_UseHardSPI = TRUE    ' Use hardware SSP port for SPI.
        ADCON1 = 15        ' All I/O pins digital
        Pause 100
        ' FSInit initializes the card and reads all the preliminary information from it
        Gosub FSInit
        Serout2 PORTC.6, 84, ["Init: ", Dec FAT_error, " ", Dec SDC_status, " ", Dec SDC_response, $d, $a]
        If (FAT_error != 0) Then Stop
        ' Display card directory
        Gosub FINDfirst        ' Find first file on card
        While (FAT_error = 0)
            Serout2 PORTC.6, 84, [Str FAT_FileName\11, $d, $a]
            Gosub FINDnext    ' Find next file on card
        Wend
    ' This section defines a specific short (8.3) filename
    '  Note that spaces are use in empty elements and must be upper case for Windows
        FAT_FileName[0] = "T"
        FAT_FileName[1] = "E"
        FAT_FileName[2] = "S"
        FAT_FileName[3] = "T"
        FAT_FileName[4] = "1"
        FAT_FileName[5] = " "
        FAT_FileName[6] = " "
        FAT_FileName[7] = " "
        FAT_FileName[8] = "T"
        FAT_FileName[9] = "X"
        FAT_FileName[10] = "T"
    ' Set file time to 8:30:10 and date to 1/1/2008
        FAT_seconds = 5
        FAT_minutes = 30
        FAT_hours = 8
        FAT_day = 1
        FAT_month = 1
        FAT_year = 28
    ' Open a file for write
        FAT_mode = "w"        ' Write mode
        Gosub FSfopen        ' Open file pointed to by Byte array FAT_FileName
        Serout2 PORTC.6, 84, ["Open for write: ", Dec FAT_error, $d, $a]
    ' Write to file
        FAT_src[0] = "A"
        FAT_src[1] = "B"
        FAT_src[2] = "C"
        FAT_count = 3
        Gosub FSfwrite
        Serout2 PORTC.6, 84, [ "Write ", Dec FAT_error, $d, $a]
    ' Close file
        Gosub FSfclose
        Serout2 PORTC.6, 84, [ "Close ", Dec FAT_error, $d, $a]
    ' Open a file for read
        FAT_mode = "r"        ' Read mode
        Serout2 PORTC.6, 84, ["Open: ", Dec FAT_error, $d, $a]
    ' Read and display the whole file
        FAT_count = 1        ' Read 1 byte to buffer at a time
        Gosub FSfread
            Serout2 PORTC.6, 84, [FAT_dest[0]]
            Gosub FSfread
        Wend
        Serout2 PORTC.6, 84, [ "Read: ", Dec FAT_error, $d, $a]
    ' Delete a file
    '    Gosub FSremove        ' Delete file pointed to by Byte array FAT_FileName
    '    Serout2 PORTC.6, 84, ["Remove: ", Dec FAT_error, $d, $a]
    '    If (FAT_error != 0) Then Stop
    ' Rename a file
    ' FAT_FileName2 is new name
    '    FAT_FileName2[0] = "T"
    '    FAT_FileName2[1] = "E"
    '    FAT_FileName2[2] = "S"
    '    FAT_FileName2[3] = "T"
    '    FAT_FileName2[4] = "2"
    '    FAT_FileName2[5] = " "
    '    FAT_FileName2[6] = " "
    '    FAT_FileName2[7] = " "
    '    FAT_FileName2[8] = "T"
    '    FAT_FileName2[9] = "X"
    '    FAT_FileName2[10] = "T"
    '    Gosub FSrename        ' Rename file pointed to by Byte array FAT_FileName
    '    Serout2 PORTC.6, 84, ["Rename: ", Dec FAT_error, $d, $a]
    May 2010
    this are the code
    I ran your code, it looks like the file SDFS3 that cam with the download, and it compiled fine.
    The only way I can reproduce your error is to try compiling SDFS.
    Using PBPL
    target is 18F4550
    What other errors are you getting?
    May 2010
    i don't have the PBPL box in my widow..here are the picture..
    May 2010
    i have use the new version of MCS..i'm using the 3.0.0.5 version. but i'm facing a new problem which is this " The Microchip assembler (MPSM) only allows up to 62 character to be used for path and filename".....
    Then simply change the location (path) and/or filename of your sourcefile so that the complete path and filename is less than 62 characters - simple as that.
    As an example, having your source files in project folder in a PIC folder in MyDocuments is bad as the full path might be:
    C:\Documents and Settings\Nurulhaiza\My Documents\PIC\MySDFSProject\Source.pbp which is 78 characters. Moving it to C:\PIC\MySDFSProject\Source.pbp will work as the path and filename now is 31 characters.
