NTP server / External (no "www") time base for PC / DCF77
Results 1 to 13 of 13
    Dec 2005
    Thumbs up
    Thanks, Charles. I've been planning to write a similar procedure although I 'm using a different ethernet adapter (WIZ110SR), different RTC (ST M41T81) and different processor (ZBasic ZX40p). Still, adapting your code should save me a lot of time and error.
    BTW, I've also used the ConnectOne nano LanReach mentioned by the OP. It has a very attractive price, easy communication protocol (patterned after modem AT commands) and a nice set of Internet protocols (e.g. SMTP/POP3 for email which are much easier to use than Lantronix). Unfortunately, Mouser will not ship it outside the USA due to Homeland Security issues.
    Also, Tibbo (http://tibbo.com/products/) has several ethernet-serial adapters some of which can be programmed in their Basic dialect. They have source examples for email, SNTP, etc. on their website. Unfortunately, their XPort like versions are not sold in the USA (I suspect because of Lantronix patents).
    Sep 2005
    Campbell, CA
    I started using Lantronix years ago, because I bought their development kit first and also because of the small size of the XPort. I built up this complex scheme of writing the setup records over the serial port (since the customer dictated that setup NOT be allowed over Ethernet). The first board (18F8720 + XPort) started out as telnet only, but I just kept adding capability. First UDP then SNMP. The SNMP part was the hardest, because - while the most devices claim to support SNMP, they mean that the device itself terminates the SNMP request. That doesn't work for me, because I needed to support SNMP reading *MY* sensors. So the XPort has to become a UDP tunnel and I have to process the SNMP packets and OIDs in my code - not trivial! I also must send SNMP traps upon errors.
    Later on, I needed SNMP and SSH/SSL simultaneously, so I used the Lantronix MatchPort AR. It handles the encryption. But setting up that device is not easy either - it uses XML records!
    The biggest challenge was finding devices that allowed relatively easy configuration and setup over the SERIAL port, and yet blocked all attempts to configure through Ethernet (and would't even respond to pings). Military protocols demand that. All the serial<->Lan people want to impress me with the easy setup over Ethernet using a GUI. I tell them that is the exact opposite of what I need!
    Like so many other cases - I'm so far down the road with Lantronix, it would be hard to switch now.
    Charles Linquist
    Dec 2005
    Quote Originally Posted by Charles Linquis View Post
    Understood. I wasn't trying to convert you, anyway. But, for people just starting with this, looking at WizNET (http://www.wiznet.co.kr/en/), ConnectOne (http://www.connectone.com/default.asp) and Tibbo (http://tibbo.com/) is a good idea if only to get an idea of the various choices available.
    PS: I also used the XPort but it was my second route. My first was with BasCom AVR.
    Aug 2008
    Portugal
    Thank you Charles!
    Thanks and Regards;
    Gadelhas
    Jul 2011
    Default Re: NTP server / External (no "www") time base for PC / DCF77
    Charles,
    Thanks for your code post. I was considering a Netburner 'PINK' module, but you've got me looking at the Lantronix Pro again. I have to admit that I'm really in the dark when doing an ethernet project!! If I'm primarily interested in sending emails and (in the future) acquiring the time, and serving up a simple web page to give input to a PIC project, what Lantronix evaluation board should I buy? I'm equally unexperienced in Linux and 'Evolution' OS's, but need to buy an eval board just to have a ready-built platform in which to experiment sending and receiving serially from my PIC to the Lantronix. With really NO experience, except for PIC's and PBP, which eval board from Lantronix would you buy?
    Thanks for your opinion, and best regards,
    Len G.
    Jul 2011
    I've decided to give Lantronix Matchport module a try. Onward.
    Dec 2005
    IIRC, Roving Network's RN-XV http://www.rovingnetworks.com/products/RN_XV WiFly module automatically contacts an NTP server and updates its onboard RTC every 4 hours. It's also quite inexpensive ($35) and connects via serial.
    Dec 2005
    My memory is a bit cloudy. (I've been in/out of hospital 7 times in past 3 months which wreaks havoc on continuity.) You supply the RN-XV an IP for a SNTP server and it can be configured to get the time at power-up and every 0-??? minutes afterwards.
    See the User Manual which you can d/l from http://www.rovingnetworks.com/resources/show/product:1
