simple xmas light project not behaving....
Results 1 to 4 of 4
    Jerson;
    Ok thats weird...
    The scale var is their if i want to slow down the change... so setting this to 1 is normal
    The duty var is actually set to 100 but for some reason it's shown as 1...
    Where did my zero's go?
    Max;
    I'm aware of DT's 3 channel PWM, however, the 18F4550 is only the development hardware i use for testing everything...
    I will be buying some lower grade pic's to do the job... i want approximately 5-10 of these running different patterns around the house both inside and out...
