simple xmas light project not behaving....
Results 1 to 4 of 4
    Default simple xmas light project not behaving....
    ok, simple little xmas lights project and i been at it for 2 weeks and it's not doing what it's supposed to...
    it's a simple 3 led software simplified PWM.... system....
    the first light 'sequence' is to fade from red into green then into blue then back to red... and the cycle repeats...
    I'm using 18F4550's with intosc... PBP 2.60A
    it brings up the red, then the green and the fades out the green and goes back to red... that's when i can get it not to power both green and red solidly at the same time...
    it's powered from a single lipol cell...
    Can someone take a look at my code and tell me if i've gone completely mad?
    Be aware, on this version i set the chip to use an external 20MHz resonator and the BOR is set wrong (corrected at programming)
    @ __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_1_1L
    @ __CONFIG _CONFIG1H, _FOSC_HS_1H & _FCMEN_ON_1H & _IESO_OFF_1H
    @ __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_1_2L & _VREGEN_OFF_2L
    @ __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_32768_2H
    @ __CONFIG _CONFIG3H, _MCLRE_OFF_3H & _PBADEN_OFF_3H
    @ __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_ON_4L &  _ICPRT_OFF_4L & _XINST_ON_4L & _DEBUG_OFF_4L
    Define  OSC				20						' Set clock speed
    TRISB = %00000000
    PORTB = %00000000
    RED VAR PORTB.7
    GREEN VAR PORTB.6
    BLUE VAR PORTB.5
    REDSCALE VAR WORD
    GREENSCALE VAR WORD
    BLUESCALE VAR WORD
    Aloop VAR byte
    Bloop VAR BYTE
    DUTY var BYTE
    clear
    REDSCALE = 1
    BLUESCALE = 1
    GREENSCALE = 1
    DUTY = 1
    gosub powerupred
    MAIN:
    gosub powerupgreen
    gosub powerdownred
    gosub powerupblue
    gosub powerdowngreen
    gosub powerupred
    gosub powerdownblue
    GOTO MAIN
    POWERUPRED:
    for Aloop = 1 to DUTY
    FOR Bloop = 1 to REDSCALE
    HIGH RED
    pause Aloop
    LOW RED
    pause (duty-Aloop)
    NEXT Bloop
    NEXT Aloop
    HIGH RED
    POWERDOWNRED:
    for Aloop = 1 to duty
    HIGH RED
    pause (duty-Aloop)
    LOW RED
    pause Aloop
    NEXT Bloop
    NEXT Aloop
    POWERUPGREEN:
    FOR Bloop = 1 to GREENSCALE
    HIGH GREEN
    pause Aloop
    LOW GREEN
    pause (duty-Aloop)
    NEXT Bloop
    NEXT Aloop
    HIGH GREEN
    POWERDOWNGREEN:
    HIGH GREEN
    pause (duty-Aloop)
    LOW GREEN
    pause Aloop
    NEXT Bloop
    NEXT Aloop
    POWERUPBLUE:
    FOR Bloop = 1 to BLUESCALE
    HIGH BLUE
    pause Aloop
    LOW BLUE
    pause (duty-Aloop)
    NEXT Bloop
    NEXT Aloop
    HIGH BLUE
    POWERDOWNBLUE:
    HIGH BLUE
    pause (duty-Aloop)
    LOW BLUE
    pause Aloop
    NEXT Bloop
    NEXT Aloop
    Jun 2008
    Milwaukee, WI
    look into Darrel Taylor's 3 channel software PWM code - it's interrupt based. I'm not sure if it's ready to run on a 18F4550. Your main loop would look something like this:
    FOR x = 0 to 255 STEP 5
    red = x 'REd fade on,
    PAUSE delay
    NEXT x
    green = x 'green fade on,
    PAUSE delay
    NEXT x
    ect...
    Bombay, India
    The code you showed has some problems for sure.
    The variables Duty and Scale are set to 1 at start. Then you do this
    POWERUPRED:
    HIGH RED
    pause Aloop
    LOW RED
    pause (duty-Aloop)
    NEXT Bloop
    NEXT Aloop
    HIGH RED
    Rewriting with your declared values it looks like this
    POWERUPRED:
    for Aloop = 1 to 1
    FOR Bloop = 1 to 1
    HIGH RED
    pause Aloop
    LOW RED
    pause (1-Aloop)
    NEXT Bloop
    NEXT Aloop
    HIGH RED
    Perhaps you see the problem now.
    Jerson;
    Ok thats weird...
    The scale var is their if i want to slow down the change... so setting this to 1 is normal
    The duty var is actually set to 100 but for some reason it's shown as 1...
    Where did my zero's go?
    Max;
    I'm aware of DT's 3 channel PWM, however, the 18F4550 is only the development hardware i use for testing everything...
    I will be buying some lower grade pic's to do the job... i want approximately 5-10 of these running different patterns around the house both inside and out...
