Math question relating to AD input on PIC12F675
Results 1 to 13 of 13
    Oct 2010
    Thanks Al. I'll add that to my code. The delay timing isn't critical but this extra code is good learning experience for me and I do appreciate it. FYI, this controller is for a small train that sits on a 12 ft shelf in the barber shop of a friend. He wants it to simply go back and forth to entertain the kids while they wait their turn to get a haircut. Who knows... some kid might be more curious about the controller, than the train, and become a PIC programmer.
    Thanks again!
    Mitch
    Oct 2010
    I thought this might be a good starter project for someone so I have attached the schematic.
    Mitch
    May 2008
    Italy
    Mitch, it is a good practice never leave inputs pins or reset floating. So I suggest you to pullup pin 4 with a 10K resistor. Apart from this well done.
    Al.
    Sep 2007
    USA, CA
    The biggest problem was not your 8 or 10 bit ad reading, or even the type of variable used for the pause command. (Pause will work with a byte.) In fact, the problem was the use of a byte var instead of a word in your calculation.... 255/4 *1000 = over 63,000... and that obviously does not fit within a byte
    Oct 2010
    Thanks for the input, Al. I build a PCB for my project today and that is when I discovered that I had left out resistors R6 and R7 from my schematic. I also realized that I had not done anything with pin 4. I went to the data sheet and, after reading, I decided to use pin 4 as MCLR. I also decided that I wanted POR active so I added the RC network that was suggested in the data sheet and then turned on those options in the PIC. I don't know the pros and cons of that decision but the MCLR and POR could be useful, in my opinion. I've updated my schematic and included it in the following attachment.
    Tenaja, thank you for looking over the code and pointing out that PAUSE will work with a byte variable. Actually, I did realize that a BYTE was not large enough for my original calculation after I had struggled with it for a long while. Thanks again!
    OK, here's the latest iteration of my circuit. This is the way I have built it onto a PCB today and it appears to be working great. Just have to experiment with the magnets under the train in order to get the spacing correct for the reed switches. I will post the final version of the code once I get a chance to update it and maybe try a couple little changes.
    Mitch
    Oct 2010
    OK, here is the final code, I hope, as I'm installing the controller for my friend sometime this week. I've incorporated the code suggestion from Al in the delay loop.
    Again, thanks to you all for the helpful suggestions, etc.
    Sincere regards,
    Mitch
    '*  Name    : Train_Auto-Reverser.pbp                           *
    '*  Author  :                                                   *
    '*  Notice  : Copyright (c) 2010                                *
    '*  Date    : 10/27/2010                                        *
    '*  Notes   : Model train auto-reversing circuit using          *
    '*          : a PIC12F675 and reed switch sensors.              *
    '   ---------Configuration--------
    ' Accepted PICBasic Pro v2.6a default configuration for PIC12F675
    '   __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    ' Also enabled PWRT and BOD during programming of PIC.
    '   ---------Defines/Constants-------
    DEFINE OSCCAL_1K 1              ' Calibrate internal oscillator
    DEFINE ADC_BITS 10              ' Set number of bits in A/D result
    DEFINE ADC_CLOCK 3              ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50          ' Set sampling time in uS
    RY1 CON 4                       ' Relay 1 (Power) to GPIO.4
    RY2 CON 5                       ' Relay 2 (Voltage reversing) to GPIO.5
    '   ---------Variables---------
    SW1     VAR GPIO.0              ' Reed switch 1 to GPIO.0
    SW2     VAR GPIO.1              ' Reed switch 2 to GPIO.1
    adval   VAR WORD                ' Store result of each A/D conversion
    delay   VAR WORD                ' Store result of math conversion
    A0      VAR BYTE                ' Index for measurement loop
    '   ---------Initialization--------
    ANSEL = %00000100               ' Set AN2 analog, all others digital
    CMCON = 7                       ' Turn off analog comparators
    ADCON0.7 = 1                    ' Right justify A/D conversion output
    '   ---------Main Code---------
    PAUSE 2000                      ' Let everything stabalize for 2 seconds.
    LOW RY2                         ' Make sure RY2 is off for forward movement.
    mainloop:
    HIGH RY1                        ' Turn on Power relay to start forward movement.
      WHILE SW1 = 1                 ' Keep RY1 active until reed switch SW1
        HIGH RY1                    ' is closed.
      WEND
    LOW RY1                         ' Removes power and stops movement.
    GOSUB delayloop                 ' Keep stopped for x number of seconds.(0-61)
    HIGH RY2                        ' Prepare RY2 for reverse movement.
    PAUSE 500                       ' Let RY2 settle before activate RY1.
    HIGH RY1                        ' Turn on power relay to start reverse movement.
      WHILE SW2 = 1                 ' Keep RY1 active until reed switch SW2
      WEND
    LOW RY2                         ' Prepare RY2 for next forward movement.
    GOTO mainloop                   ' Keep repeating until user terminated.
    delayloop:
    Delay = 0                        ' Zero out variable
     FOR A0 = 1 to 10                ' Take 10 readings
       ADCIN 2, adval                ' Read A/D channel 2 into adval variable.
       Delay = Delay + adval
     NEXT A0
    delay = delay * 6               ' Creates values for PAUSE command that
    PAUSE delay                     ' allow delays from approx. 0 to 61 seconds.
