Simple player x isd1760 chip corder
Results 1 to 19 of 19
    You could remove the two "Optional" blocks on the lower right, and you could remove the microphone. However, you would not have a way to record anything into your device. You could remove all push buttons except for play. The data sheet says to keep all the other capacitors in there for good voice quality. You can probably get rid of the LED. I'm not really sure about what else you could give up. Reset seems nice to have.
    EDIT : I did find a schematic someone made for an alarm clock that used the ISD1700 series. It has omitted many parts that the data sheet recommended. Not sure about the quality difference. Attached is that schematic.
    http://www.scalerobotics.com
    Oct 2010
    Scalerobotics,
    Thank you for your help, I'll try to ride this circuit without the unnecessary parts and see what happens. Later I put here the appropriate comments.
    Thanks.
    rachna12's Avatar
    rachna12 Guest
    Default Re: Simple player x isd1760 chip corder
    These are really good one and worthy to visit here. I think so that this one is great
    totally relevant to the post and it was good experience to read
    Note By Alain ...
    This is the typical Spammer ... no real link to the thread !
    banned after controlling links placed in his profile ...
