pulsin fails in real world
Results 1 to 2 of 2
    Feb 2005
    Default pulsin fails in real world
    I have this program for pic 12F683, I resumed the program for the relevant parts (of course all variables are properly defined):
    @ device INTRC_OSC_NOCLKOUT
    DEFINE PULSIN_MAX 65535
    ansel=0
    trisio=%00100000
    pulso VAR WORD
    boton VAR GPIO.5
    LED VAR GPIO.2
    pwmduty VAR BYTE[7] '
    pwmduty[0]= 16
    pwmduty[1]= 32
    pwmduty[2]= 64
    pwmduty[3]= 127
    pwmduty[4]= 150
    pwmduty[5]= 192
    pwmduty[6]= 255
    prendido=0
    pwmstat=6
    frecu=250
    testigo=0
    LOOP:
    tdp=2
    PulsIn boton, 0, pulso
    Pause 10
    IF pulso >0 Then
    IF pulso > 20000 Then
    TDP=3
    Else
    tdp=1
    EndIF
    EndIF
    Select Case tdp
    Case 1
    IF prendido =1 Then
    prendido =0
    HPwm 1,0,frecu
    Else
    prendido=1
    HPwm 1,pwmduty[pwmstat],frecu
    EndIF
    Case 3
    GoSub spwm
    End Select
    tdp=2
    GoTo loop
    the program is the main loop for a multilevel light, the subroutine sets the pwm duty cycle.
    well it simulates ok, but in the real world, the circuit behaves totally erratic
    Im guess the problem is in the switch, but I'm completelly lost. Or maybe the Hardware PWM is not working ok?
    What can I do?
    thanks in advance
    i didn't check your whole code but, have you try with a pulse generator instead of the switches?? if so, what are the results?
    did you use a scope to see PWM and Switches signal. What about your supply line (again and again)
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 11:17
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  4. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 14:52
  5. PULSIN and RCTIME
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 15:45
