SPI and I2C
Results 1 to 8 of 8
Thread: SPI and I2C
    USA - Arizona
    Am I right in stating that with the said PIC having hardware SPI that it would be better to use that (following the example given) as networking is more demanding than using I2C to read the DS1307 chip.
    That would be my recommendation.
    Below is some code I previously used with a different basic compiler (note that the SSPCON register is sometimes defined as SSPCON1 register on newer chips).
    'Include file for HW SPI (master only)
    'Procedures:
    '> PROC spi_prep(mode As Byte, clock As Byte)
    '>> mode-> 0 for Mode 0,0 ; 1 for Mode 0,1 ; 2 for Mode 1,0 ; 3 for Mode 1,1
    '>> clock -> 0 for CLK/4 ; 1 for CLK/16 ; 2 for CLK/64 ; 3 for TMR2/4
    '> PROC spi_send(spi_data As Byte)
    '> FUNCTION spi_receive(spi_data As Byte) As Byte
    '>> can be used to send and receive data
    Proc spi_prep(mode As Byte, clock As Byte)
    	Select Case mode
    		Case 0  'SPI_MODE 0,0
    			SSPCON.SSPEN = 1
    			SSPCON.CKP = 0
    			SSPSTAT.CKE = 1
    			SSPSTAT.SMP = 0
    		Case 1  'SPI_MODE 0,1
    			SSPCON.SSPEN = 1
    			SSPCON.CKP = 0
    			SSPSTAT.CKE = 0
    			SSPSTAT.SMP = 0
    		Case 2  'SPI_MODE 1,0
    			SSPCON.SSPEN = 1
    			SSPCON.CKP = 1
    			SSPSTAT.CKE = 1
    			SSPSTAT.SMP = 0
    		Case 3  'SPI_MODE 1,1
    			SSPCON.SSPEN = 1
    			SSPCON.CKP = 1
    			SSPSTAT.CKE = 0
    			SSPSTAT.SMP = 0
    		Case Else  'set for SPI_MODE 0,0
    			SSPCON.SSPEN = 1
    			SSPCON.CKP = 0
    			SSPSTAT.CKE = 1
    			SSPSTAT.SMP = 0
    	EndSelect
    	Select Case clock
    		Case 0  'SPI_CLOCK = OSC/4
    			SSPCON.SSPM3 = 0
    			SSPCON.SSPM2 = 0
    			SSPCON.SSPM1 = 0
    			SSPCON.SSPM0 = 0
    		Case 1  'SPI_CLOCK = OSC/16
    			SSPCON.SSPM3 = 0
    			SSPCON.SSPM2 = 0
    			SSPCON.SSPM1 = 0
    			SSPCON.SSPM0 = 1
    		Case 2  'SPI_CLOCK = OSC/64
    			SSPCON.SSPM3 = 0
    			SSPCON.SSPM2 = 0
    			SSPCON.SSPM1 = 1
    			SSPCON.SSPM0 = 0
    		Case 3  'SPI_CLOCK = TMR2/2
    			SSPCON.SSPM3 = 0
    			SSPCON.SSPM2 = 0
    			SSPCON.SSPM1 = 1
    			SSPCON.SSPM0 = 1
    		Case Else  'SPI_CLOCK = OSC/4
    			SSPCON.SSPM3 = 0
    			SSPCON.SSPM2 = 0
    			SSPCON.SSPM1 = 0
    			SSPCON.SSPM0 = 0
    	EndSelect
    End Proc
    Proc spi_send(spi_data As Byte)
    	SSPBUF = spi_data
    	While SSPSTAT.BF = 0
    	Wend  'Wait until buffer is clear
    End Proc
    Function spi_receive(spi_data As Byte) As Byte
    	SSPBUF = spi_data
    	spi_receive = SSPBUF
    End Function
    the alternate suggestion would be to use a pic that has two mssp's if both sets of comms are time critical...
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by comwarrior View Post
    True... I'll start browsing Microchips website to see if there is one which still has the same functionality as the 18F4580 but with dual mssp's and still retain a 40 pin DIL package !
    malc-c's Avatar
    malc-c Guest
    Well I think I'm scuppered... Just spent best part of this morning comparing various PICs and thought I had found the ideal replacement for the 18F4580. Unfortunately the second MSSP used pins on PORT B, which is currently used for the LCD and to use this alternative would require a complete re-design of the PCB
