Problem getting switch info into FOR..NEXT Start
Results 1 to 3 of 3
    Apr 2009
    Unhappy Problem getting switch info into FOR..NEXT Start
    '* Name : No Smoke *
    '* Author : Roddy Wayne *
    '* Notice : *
    '* Date : 10/23/2010 *
    '* Version : 1.0 *
    '* Notes : *
    CLEAR ;always start with clear
    DEFINE OSC 4 ;define oscillator speed
    define DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    define DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 0
    DEFINE DEBUG_PACING 1000
    ADCON1 = 7
    TRISA = %11111111 ;sets porta as inputs
    TRISB = %11111111 ;sets portb pins as inputs
    TRISC = %00000000 ;sets portc pins as outputs
    TRISD = %00000000 ;sets portd pins as outputs
    TRISE = %00000000 ;sets porte pins as outputs
    B0 Var Byte 'B0, B2, and B4 all variable bytes
    B2 Var Byte
    B4 Var Byte
    Start:
    Pause 100 'pause .1 second
    B0 = PortB 'Read PortB, put it in B0
    B2 = PortA 'Read PortA, put it in B2
    'Debug 14, 1, "B0 Byte = ", BIN8 B0, " ", 13'Display Byte B0, & next line
    'Debug "B2 Byte = ", Bin8 B2, " " 'Display Byte B2
    Pause 1000 'Wait a second
    Debug 14 'Light up LCD
    If (B0 = %00000000) Then Start 'If no input, go to Start
    If (B2 <%00000011) Then Start 'Case must be CLOSED! (bit 1)
    If (B0 >=%00000001) And (B2>=%00000011) Then LEDS 'If input, go to LEDS
    LEDS: ''''''''''''''''''PLEASE READ''''''''''''''''''''''''''
    'Below is where I'm having a problem. I have not been able to search this
    'Forum and find out how to read 8 Dip Switches connected to PortB (inputs)
    'and transfer this Data into FOR..NEXT Start. TO will be 0 and STEP will
    'be - 1. (Because I've added the "FOR B0 =%00000100" line, the code below
    'does run correctly. Any advice or help will be greatly appreciated!)
    ''''''''''''''''''''''''''''THANK YOU!''''''''''''''''''''''''''''''
    For B0 =%00000100 to 0 Step -1
    High PortC.0 'Led On
    Pause 500 'Wait .5 second
    Low PortC.0 'Led Off
    High PortC.7 'Beeper On
    Low PortC.7 'Beeper Off
    Pause 50
    Debug 1, "B0 Byte = ", Bin8 B0, " "
    Pause 58000 'Wait about 1 minute (total)
    Next B0 'Dec Next B0
    High PortC.4 'Led On (Gives me a visual before 4 second delay)
    Pause 500 'Pause .5 second
    Low PortC.4 'Led Off
    Pause 4000 'Pause 4 seconds (gives plenty of time for testing)
    Goto Start
    Not exactly sure what you want to do here but how about
    myValue VAR BYTE
    myValue = PortB
    For B0 = myValue to 0 Step -1
    Next
    Or probably even
    For B0 = PortB to 0 Step -1
    Next
    Apr 2009
    Red face I couldn't see the forest for the trees!
    myValue VAR BYTE
    myValue = PortB
    Next
    Or probably even
    Next
    Thanks Henrik! I feel like an IDIOT!
    "For B0 = PortB to 0 Step -1"
    Works just fine!
