Doing Simple Math - getting the wrong answer
Results 1 to 4 of 4
    anj's Avatar
    anj Guest
    First - theBase # is "223" This is the value in #Dec_temp
    Then look at the math:
    Testmath1 - (Dec_temp*(9/5)+32) = 255 -- this is wrong
    PBP uses full precedence of math operators, and also uses braces to force out of order of calculation.
    Secondly it also only works in integers.
    As such (9/5) = 1.8 = 1 ( and is calculated first )
    hence Dec_tempf = 223 * 1 +32 = 255
    try ( Dec_temp*( 90 / 5 ) + 320 ) / 10
    ie ( Dec_temp*18 + 320 ) / 10
    Also, if you just leave it at ( Dec_temp*18 + 320 ) you can use simple math to get the basic temp and the first decimal.
    Andrew
    Post
    Hi Tom,
    PBP can't handle fractions very well, the "**" and "*/" operators however makes it possible. 9/5 is 1.8 which PBP will trunctate to 1, not very useful. The "**" operator can handle the fractional part, this operaton makes an "invisible" division by 65536. 0.8*65536=52428.8 which we round up to 52429. Since your Dec_temp variable contains the temerature in tenths of a degree your formula needs to be ......
    Dec_tempf=Dec_temp*(9/5) + 320 'Farenheit * 10
    We rewrite this to ...
    Dec_tempf=Dec_temp*1.8 + 320 'Farenheit * 10
    Which is the same as .....
    Dec_tempf=Dec_temp*1+Dec_temp*0.8 + 320 'Farenheit * 10
    Using "**", we end up with ......
    Dec_tempf=Dec_temp + Dec_temp**52429 + 320
    Another thing, you can replace ......
    ' read data for temperature Temp
    SSD4= (ssmax[24]>>4)
    SSD3= (ssmax[24] & $f)
    SSD2= (ssmax[23]>>4)
    SSD1= (ssmax[23] & $f)
    ' convert to Decimal:
    Dec_temp=(ssd4*4096)+(ssd3*256)+(ssd2*16)+ssd1
    ...... with ......
    Dec_temp.highbyte = ssmax[24]
    Dec_temp.lowbyte = ssmax[23]
    /Ingvar
    Italy
    Fahrenheit = Celsius * (212 - 32)/100 + 32
    Example 30 Celsius to Fahrenheit:
    30 * 180 / 100 + 32 = 86 Fahrenheit
    Best regards,
    Luciano
  1. Simple Maths Going Wrong
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 27th May 2010, 10:01
  2. what's wrong 16F877A simple code?
    Last Post: - 30th October 2009, 02:11
  3. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 11:22
  4. not quite understanding the MATH function
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 17th January 2006, 21:20
  5. Simple Math
    By brenda in forum mel PIC BASIC Pro
    Last Post: - 17th August 2005, 18:47
