Help to setup GPS connection.
Results 1 to 34 of 34
    You are right, a word only goes up to 65535. If you have PBP v 2.5 or later, (and were using a PIC18 chip) you could select to use PBPL to compile, and define your large variables as LONG instead of WORD.
    If you want to stick with the PIC16 series, you could use N-BIT math. http://www.picbasic.co.uk/forum/cont...153-N-Bit_MATH
    By the way, it looks like you are using PM as your assembler.
    @ DEVICE HS_OSC
    You probably need to use MPASM for N-Bit Math to work. For that, you define your configs like this:
    @ __config _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF
    But you must comment out the configs in you C:/PBP/16F877A.INC file.
    See : http://www.picbasic.co.uk/forum/cont...o-your-Program
    http://www.scalerobotics.com
    Oct 2008
    Hi scalerobotics, I got my setup using Mpasm, and trying to figure out how Darrel's N-Bit_Math works, I need a sample to study its output. Try to use wozzy's code in pic16f877A
    PRECISION CON 8 SYSTEM  	' 8 bytes = 64-bit
    INCLUDE "N-Bit_Math.pbp"	' Include Alexander Avtanski's Multibyte Arithmetic
    				' Assembly Library Wrapped for PBP by Darryl Taylor
    				' Version:1.3 Beta (1/7/2010)
    ;@ DEVICE HS_OSC
    DEFINE OSC 20			' 20 MHz Crystal Oscillator
    DEFINE DEBUG_REG PORTC		' PORT C6
    DEFINE DEBUG_BIT 6 			' PORT C6
    DEFINE DEBUG_BAUD 57600		' BAUD 57600
    DEFINE DEBUG_MODE 0 		' 1 = inverted, 0 = true
    I			VAR	BYTE
    AA64 		VAR BYTE[PRECISION]
    BB64		VAR BYTE[PRECISION]
    CC64     	VAR BYTE[PRECISION]
    DD64		VAR BYTE[PRECISION]
    XX64		VAR BYTE[PRECISION]
    YY64		VAR BYTE[PRECISION]
    ZZ64		VAR BYTE[PRECISION]
    PAUSE 500 : DEBUG "   ",10,13,10,13 : PAUSE 500
    MAIN:
    	@  MATH_MUL  _AA64, _BB64, _XX64	; @  MATH_MUL  _A, _B, _Res ; Res = A / B - Remainder in REG_Z
    	@  MATH_DIV  _CC64, _DD64, _YY64	; @  MATH_DIV  _A, _B, _Res ; Res = A / B - Remainder in REG_Z
    	@  MATH_DIV  _DD64, _CC64, _ZZ64	; @  MATH_DIV  _A, _B, _Res ; Res = A / B - Remainder in REG_Z
    	DEBUG "BYTE ORDER BYTE[7],BYTE[6],BYTE[5],BYTE[4],BYTE[3],BYTE[2],BYTE[1],BYTE[0]",10,13,10,13
    	DEBUG "AA64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 AA64[I] : NEXT I : DEBUG 10,13
    	DEBUG "BB64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 BB64[I] : NEXT I : DEBUG 10,13
    	DEBUG "CC64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 CC64[I] : NEXT I : DEBUG 10,13
    	DEBUG "DD64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 DD64[I] : NEXT I : DEBUG 10,13
    	DEBUG "XX64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 XX64[I] : NEXT I : DEBUG 10,13
    	DEBUG "YY64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 YY64[I] : NEXT I : DEBUG 10,13
    	DEBUG "ZZ64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 ZZ64[I] : NEXT I : DEBUG 10,13
    	DEBUG "REG_Z = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 REG_Z[I] : NEXT I : DEBUG 10,13
    	DEBUG 10,13,10,13,10,13,10,13
    	PAUSE 10000
    GOTO MAIN
    I don't have any display on the hyper terminal window, My first time to encounter DEBUG command, but I think its similar to Serout2, is not it?
    regards,
    mbox
