Help to setup GPS connection.
Results 1 to 34 of 34
    Oct 2008
    I am trying to run this code...
    define OSC 20
    gpsin var portc.7 'rx
    gpsout var portc.6 'tx
    HH VAR byte
    MM VAR BYTE
    SS VAR BYTE
    ND VAR BYTE
    NM VAR BYTE
    NMD VAR WORD
    WD VAR BYTE
    WM VAR BYTE
    WMD VAR WORD
    AR VAR BYTE[20]
    START:
    SERIN2 gpsin,16572,[WAIT("$GPGGA"),WAIT(","),DEC2 hH,DEC2 mM,DEC2 sS,_
    WAIT(","),DEC2 ND,DEC2 NM,WAIT("."),DEC3 NMD,WAIT(",N,"),_
    DEC3 WD,DEC2 WM,WAIT("."),DEC3 WMD]
    PAUSE 1000
    SEROUT2 gpsout,16572,[DEC2 HH,DEC2 MM,DEC2 SS,_
    DEC2 ND,DEC2 NM,DEC3 NMD,DEC3 WD,DEC2 WM,DEC3 WMD,13,10]
    goto start
    I'm testing PC to MCU first, but I don't have response when entering $GPGGA,114708.600,1114.5089,N,12500.3864,E,1,6,1.6 7,23.5,M,55.4,M,,*69
    regards,
    mbox
    Oct 2008
    Post
    I manage to run this code for a start
    @ DEVICE HS_OSC
    DEFINE    OSC 20
    serout2 PortC.6,32774,["To PC",$D]  ;@38400 To PC
    serout2 PortB.6,84,[$1B,$45]
    serout2 PortB.6,84,["To LCD"] ;@9600 To Lcd
    I will update my codes with the Gps, and post it here later...
    regards,
    mbox
    That is more like it.
    Start small and build your way up
    Oct 2008
    I'm trying to add two numbers, 1st number is 140000 and the 2nd is 5377 which will give me 145377. And after getting the sum it will be divided by 60. x= (140000+ 537)/60, I think WORD can not hold much of the integers I need.
    Ho do I do this in PBP?
    You are right, a word only goes up to 65535. If you have PBP v 2.5 or later, (and were using a PIC18 chip) you could select to use PBPL to compile, and define your large variables as LONG instead of WORD.
    If you want to stick with the PIC16 series, you could use N-BIT math. http://www.picbasic.co.uk/forum/cont...153-N-Bit_MATH
    By the way, it looks like you are using PM as your assembler.
    @ DEVICE HS_OSC
    You probably need to use MPASM for N-Bit Math to work. For that, you define your configs like this:
    @ __config _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF
    But you must comment out the configs in you C:/PBP/16F877A.INC file.
    See : http://www.picbasic.co.uk/forum/cont...o-your-Program
    http://www.scalerobotics.com
    Oct 2008
    Hi scalerobotics, I got my setup using Mpasm, and trying to figure out how Darrel's N-Bit_Math works, I need a sample to study its output. Try to use wozzy's code in pic16f877A
    PRECISION CON 8 SYSTEM  	' 8 bytes = 64-bit
    INCLUDE "N-Bit_Math.pbp"	' Include Alexander Avtanski's Multibyte Arithmetic
    				' Assembly Library Wrapped for PBP by Darryl Taylor
    				' Version:1.3 Beta (1/7/2010)
    ;@ DEVICE HS_OSC
    DEFINE OSC 20			' 20 MHz Crystal Oscillator
    DEFINE DEBUG_REG PORTC		' PORT C6
    DEFINE DEBUG_BIT 6 			' PORT C6
    DEFINE DEBUG_BAUD 57600		' BAUD 57600
    DEFINE DEBUG_MODE 0 		' 1 = inverted, 0 = true
    I			VAR	BYTE
    AA64 		VAR BYTE[PRECISION]
    BB64		VAR BYTE[PRECISION]
    CC64     	VAR BYTE[PRECISION]
    DD64		VAR BYTE[PRECISION]
    XX64		VAR BYTE[PRECISION]
    YY64		VAR BYTE[PRECISION]
    ZZ64		VAR BYTE[PRECISION]
    PAUSE 500 : DEBUG "   ",10,13,10,13 : PAUSE 500
    MAIN:
    	@  MATH_MUL  _AA64, _BB64, _XX64	; @  MATH_MUL  _A, _B, _Res ; Res = A / B - Remainder in REG_Z
    	@  MATH_DIV  _CC64, _DD64, _YY64	; @  MATH_DIV  _A, _B, _Res ; Res = A / B - Remainder in REG_Z
    	@  MATH_DIV  _DD64, _CC64, _ZZ64	; @  MATH_DIV  _A, _B, _Res ; Res = A / B - Remainder in REG_Z
    	DEBUG "BYTE ORDER BYTE[7],BYTE[6],BYTE[5],BYTE[4],BYTE[3],BYTE[2],BYTE[1],BYTE[0]",10,13,10,13
    	DEBUG "AA64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 AA64[I] : NEXT I : DEBUG 10,13
    	DEBUG "BB64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 BB64[I] : NEXT I : DEBUG 10,13
    	DEBUG "CC64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 CC64[I] : NEXT I : DEBUG 10,13
    	DEBUG "DD64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 DD64[I] : NEXT I : DEBUG 10,13
    	DEBUG "XX64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 XX64[I] : NEXT I : DEBUG 10,13
    	DEBUG "YY64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 YY64[I] : NEXT I : DEBUG 10,13
    	DEBUG "ZZ64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 ZZ64[I] : NEXT I : DEBUG 10,13
    	DEBUG "REG_Z = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 REG_Z[I] : NEXT I : DEBUG 10,13
    	DEBUG 10,13,10,13,10,13,10,13
    	PAUSE 10000
    GOTO MAIN
    I don't have any display on the hyper terminal window, My first time to encounter DEBUG command, but I think its similar to Serout2, is not it?
    regards,
    mbox
    Quote Originally Posted by mbox View Post
    is this still part of the GPS project or something new?
    Either way, where are the numbers coming from?
    Oct 2008
    Yes it's part of the GPS. Google map can interpret this "11 14.5377,125 00.3560". But for my Mobile map application it can not, it reads this format "11.242295, 125.005933", I will explain my alternative solution only for th the latitude part using data "$GPRMC,115209.200,A,1114.5377,N,12500.3439,E,0.02 ,296.54,021110,,,A*65", I extract data to this format "Deg 11 Min 14 Sec 5377". Then I need 14 and 5377 to be this 145377 format (my alternative solution is to 14x10000+5377) then divide it by 60 which will give me 2422.95. I need to make it whole number so 2422.95 x 100 = 242295. Then format the data to this deg 11.242295 ans send it to PortC.6, 11 is the degree and add a "." in between. Any alternative solution would be nice.
    regards,
    mbox
    Not quite the accuracy you want but it is close. Maybe someone else can get it closer.
    This returns 2422.
        K   CON 10000
        MINS VAR BYTE
        SECS VAR WORD
        MINS = 14
        SECS = 5377
        Y   VAR WORD
        Z   VAR WORD     'DUMMY VAR
        Z1  VAR WORD     'DUMMY VAR
        START:
        SECS = SECS / 10
        Z = (MINS * K)
        Z1 = DIV32 10
        Y = Z1 + SECS
        Z = (Y / 6)
        LCDOUT $FE,1,"Z= ",DEC Z
    Default minutes and seconds to degrees
    Hey Mbox,
    I think you are close, but your degrees calculation is a little off (if I am right about you converting minutes and seconds to degrees). I know a short cut, if you can live without decimal seconds.
    Say you want to convert 11 deg 14 min and 53.77 seconds to degrees. If you can live without decimal seconds, we have 11 deg 14 min and 54 seconds. To convert to degrees.degrees:
    to convert minutes to degrees
    (14 * 500)/3 = 2333 (really .2333 degrees)
    and now convert seconds
    (54 * 50)/18 = 150 (really .015 degrees)
    2333
    +150
    =2483
    or 11.2483 degrees. This result fares well with http://www.satsig.net/degrees-minute...calculator.htm , which says the result should be 11.24827 using the seconds decimals.
    So with two variables you could store the result. lon_hi would = 11 and lon_low would = 2483. If you need to turn this out the serial port, your code can also place the decimal point between them.
