Help to setup GPS connection.
Results 1 to 34 of 34
    You would be better off using SERIN2.
    Here is a snippet from something .
    SERIN2 PORTB.2,16572,[WAIT("$GPGGA"),WAIT(","),DEC2 H,DEC2 M,DEC2 S,_
            WAIT(","),DEC2 ND,DEC2 NM,WAIT("."),DEC3 NMD,WAIT(",N,"),_
            DEC3 WD,DEC2 WM,WAIT("."),DEC3 WMD]
    Oct 2008
    Hi, I'm trying to understand SERIN2 command. why this code do not work when I entered "hello"?
    Include "modedefs.bas"
    Serin2 PORTC.7, T9600, error, [WAIT("hello")]
    serout2 PortC.6, T9600, ["Valid"]
    error:
    serout2 PortC.6, T9600, ["Invalid"]
    regards,
    mbox
    I imagine many are thinking, "have you read the manual?".
    Does nothing with SERIN2/SEROUT2.
    T9600
    Is for SERIN/SEROUT. "T" is for true mode anyways so if you are connecting directly to a PC you want INVERTED mode.
    Appendix A from the manual has the modes for SERIN2. At 9600 baud the mode will be 16468. To see how that is calculated look here. http://www.picbasic.co.uk/forum/cont...SERIN2-SEROUT2
    You will also want to specify a time for the GOTO LABEL "error".
    Try this
    SERIN2 PORTC.7, 16468,100, error, [WAIT("hello")]
    The above will wait for 100 milliseconds, then GOTO "error" if "hello" is not received.
    Oct 2008
    Red face
    Hi mackrackit, thanks for the help, appreciated very much. I manage to run this code MCU to PC and use this guide http://melabs.com/resources/ser2modes.htm
    SERIN2 PORTC.7, 84,200, error, [WAIT("Hello")]
    serout2 PortC.6,84, ["Valid",10,13]
    error:
    serout2 PortC.6, 84, ["Invalid",10,13]
    I know u have given me an example, but dont really get it ,
    Is there a way I could receive this value "$GPRMC,053740.000" and place it on a variable?
    thanks and regards,
    mbox
        H       VAR BYTE 'HOURS
        M       VAR BYTE 'MINUTES
        S       VAR BYTE 'SECONDS
    [WAIT("$GPRMC"),WAIT(","),DEC2 H,DEC2 M,DEC2 S]
    Waits for GPRMC
    Waits for ","
    Places the first two digits into VAR H
    Places the middle two digits into VAR M
    Places the last two digits into VAR S
    "$GPRMC,053740.000"
    053740 =
    H = 05 Hours
    M = 37 Minutes
    S = 40 Seconds
    If you have not seen this it might be handy
    http://aprs.gids.nl/nmea/
    Oct 2008
    Thumbs up
        H       VAR BYTE 'HOURS
        M       VAR BYTE 'MINUTES
        S       VAR BYTE 'SECONDS
    Waits for GPRMC
    Waits for ","
    "$GPRMC,053740.000"
    053740 =
    H = 05 Hours
    M = 37 Minutes
    S = 40 Seconds
    Thanks so much mackrackit.
    regards,
    mbox
    Oct 2008
    Hi, I want to try to use 38400 baud rate with 20Mz crystal. I want to test it first in the hyperterminal by entering this line "$GPGGA,115209.600,1114.5166,N,12500.3439,E,1,10,0 .83,16.9,M,55.4,M,,*5E" and I use this code
    DEFINE HSER_SPBRG 32 ' 38400 Baud @ -1.36%
    define HSER_BAUD 38400
    define OSC 20
    gpsin var portc.7 'rx
    gpsout var portc.6 'tx
    HH VAR byte
    MM VAR BYTE
    SS VAR BYTE
    ND VAR BYTE
    NM VAR BYTE
    NMD VAR WORD
    WD VAR BYTE
    WM VAR BYTE
    WMD VAR WORD
    AR VAR BYTE[20]
    START:
    SERIN2 gpsin,16572,[WAIT("$GPGGA"),WAIT(","),DEC2 hH,DEC2 mM,DEC2 sS,_
    PAUSE 1000
    SEROUT2 gpsin,16572,[DEC2 HH,DEC2 MM,DEC2 SS,_
    DEC2 ND,DEC2 NM,DEC3 NMD,DEC3 WD,DEC2 WM,DEC3 WMD,13,10]
    goto START
    but I dont have any display on the recieve window. Please help..
    regards,
    mbox
