Help to setup GPS connection.
Results 1 to 34 of 34
    Oct 2008
    Finally I manage to make the baudrate to 9600 with this guide http://docs.trenz-electronic.de/GlobalT ... ket_01.pdf but I have not connected it yet to PIC16F877A.
    I'm going to use SERIN on PortB.0 to fetch data from GPS using 4Mz crytsal....feed back you later the result when I get back home.
    regards,
    mbox
    Oct 2008
    Hi, I got a follow up question, I need to get latitude and longitude from this string
    $GPRMC,053740.000,A,250.6319,N,12136.0099,E,2.69,7 9.65,100106,,,A*53. How can I achieve it using SERIN?
    thanks,
    mbox
    You would be better off using SERIN2.
    Here is a snippet from something .
    SERIN2 PORTB.2,16572,[WAIT("$GPGGA"),WAIT(","),DEC2 H,DEC2 M,DEC2 S,_
            WAIT(","),DEC2 ND,DEC2 NM,WAIT("."),DEC3 NMD,WAIT(",N,"),_
            DEC3 WD,DEC2 WM,WAIT("."),DEC3 WMD]
    Oct 2008
    Hi, I'm trying to understand SERIN2 command. why this code do not work when I entered "hello"?
    Include "modedefs.bas"
    Serin2 PORTC.7, T9600, error, [WAIT("hello")]
    serout2 PortC.6, T9600, ["Valid"]
    error:
    serout2 PortC.6, T9600, ["Invalid"]
    regards,
    mbox
    I imagine many are thinking, "have you read the manual?".
    Does nothing with SERIN2/SEROUT2.
    T9600
    Is for SERIN/SEROUT. "T" is for true mode anyways so if you are connecting directly to a PC you want INVERTED mode.
    Appendix A from the manual has the modes for SERIN2. At 9600 baud the mode will be 16468. To see how that is calculated look here. http://www.picbasic.co.uk/forum/cont...SERIN2-SEROUT2
    You will also want to specify a time for the GOTO LABEL "error".
    Try this
    SERIN2 PORTC.7, 16468,100, error, [WAIT("hello")]
    The above will wait for 100 milliseconds, then GOTO "error" if "hello" is not received.
    Oct 2008
    Red face
    Hi mackrackit, thanks for the help, appreciated very much. I manage to run this code MCU to PC and use this guide http://melabs.com/resources/ser2modes.htm
    SERIN2 PORTC.7, 84,200, error, [WAIT("Hello")]
    serout2 PortC.6,84, ["Valid",10,13]
    error:
    serout2 PortC.6, 84, ["Invalid",10,13]
    I know u have given me an example, but dont really get it ,
    Is there a way I could receive this value "$GPRMC,053740.000" and place it on a variable?
    thanks and regards,
    mbox
        H       VAR BYTE 'HOURS
        M       VAR BYTE 'MINUTES
        S       VAR BYTE 'SECONDS
    [WAIT("$GPRMC"),WAIT(","),DEC2 H,DEC2 M,DEC2 S]
    Waits for GPRMC
    Waits for ","
    Places the first two digits into VAR H
    Places the middle two digits into VAR M
    Places the last two digits into VAR S
    "$GPRMC,053740.000"
    053740 =
    H = 05 Hours
    M = 37 Minutes
    S = 40 Seconds
