Help to setup GPS connection.
Results 1 to 34 of 34
    Oct 2008
    Default Help to setup GPS connection.
    Hi everyone, I have a GPS with 57600 baud rate and runs on 3.3v, I'm using Pic16F877A with 4Mz crystal. I'm planning to use Serin to read GPS data on PortB.0 and use PortC.6 for Serout to transmit it an LCD or to PC. Do I need to have voltage divider...please give advice.
    thanks
    mbox
    Read this
    http://www.picbasic.co.uk/forum/showthread.php?t=5667
    To give you a good answer we would need the data sheet of the GPS.
    Quote Originally Posted by mbox View Post
    That's a little too high a baud rate for 4 mhz to handle. I think you will have better luck trying 57600 with a 20 mhz crystal.
    http://www.scalerobotics.com
    Oct 2008
    Read this
    So far based on what I read I think, voltage divider is not needed because I just want data reading from GPS(LS20031) to MCU or PC.
    For GPS to Pic16F877A
    GPS Tx--> Mcu Rx
    For GPS to PC
    GPS Tx--> PC Rx
    thanks and regards,
    mbox
    Oct 2008
    okay I will try to change the crystal and update you the results.
    thanks and regards,
    mbox
    GPS Tx--> Mcu Rx
    For GPS to PC
    GPS Tx--> PC Rx
    The LS20031 is TTL, and not RS-232. So you will not be able to send it out directly to the PC. You will need something like a max232, or an equivalent to invert the signal levels.
    Your PIC should be able to receive the TTL at 3.3v, even though I am guessing the PIC is at 5v. Just don't TX from the PIC to the GPS without a level shifter.
    Oct 2008
    Sorry its been a while, been busy working with other things.
    Thanks for the info...one more question, I don't have 20Mz crystal, but I do have 20.945 Cyrstal, can I use it?
    thanks in advance,
    mbox
    For the baud rate to be timed right, PicBasic needs to told exactly what frequency the crystal is. PicBasic only allows certain crystals to be defined. Here are the settings allowed: MHz: 3(3.58) 4 8 10 12 16 20 24 25 32 33 40 48 64. Of course your chip has restrictions as well. (It max's out at 20 mhz).
    If you have a 16mhz crystal, you might give it a try while you wait for a 20mhz to come in. 38400 baud works with debug out at 8 mhz, so at 16mhz I figure your 57600 might work. In the meantime, you could connect the gps to a max232 device, and change the baud lower with your computer. Then you could connect it to your pic at a lower baud rate, using a lower speed crystal. But 20mhz is highly recommended.
    Oct 2008
    Finally I manage to make the baudrate to 9600 with this guide http://docs.trenz-electronic.de/GlobalT ... ket_01.pdf but I have not connected it yet to PIC16F877A.
    I'm going to use SERIN on PortB.0 to fetch data from GPS using 4Mz crytsal....feed back you later the result when I get back home.
    regards,
    mbox
    Oct 2008
    Hi, I got a follow up question, I need to get latitude and longitude from this string
    $GPRMC,053740.000,A,250.6319,N,12136.0099,E,2.69,7 9.65,100106,,,A*53. How can I achieve it using SERIN?
    thanks,
    mbox
    You would be better off using SERIN2.
    Here is a snippet from something .
    SERIN2 PORTB.2,16572,[WAIT("$GPGGA"),WAIT(","),DEC2 H,DEC2 M,DEC2 S,_
            WAIT(","),DEC2 ND,DEC2 NM,WAIT("."),DEC3 NMD,WAIT(",N,"),_
            DEC3 WD,DEC2 WM,WAIT("."),DEC3 WMD]
    Oct 2008
    Hi, I'm trying to understand SERIN2 command. why this code do not work when I entered "hello"?
    Include "modedefs.bas"
    Serin2 PORTC.7, T9600, error, [WAIT("hello")]
    serout2 PortC.6, T9600, ["Valid"]
    error:
    serout2 PortC.6, T9600, ["Invalid"]
    regards,
    mbox
    I imagine many are thinking, "have you read the manual?".
    Does nothing with SERIN2/SEROUT2.
    T9600
    Is for SERIN/SEROUT. "T" is for true mode anyways so if you are connecting directly to a PC you want INVERTED mode.
    Appendix A from the manual has the modes for SERIN2. At 9600 baud the mode will be 16468. To see how that is calculated look here. http://www.picbasic.co.uk/forum/cont...SERIN2-SEROUT2
    You will also want to specify a time for the GOTO LABEL "error".
    Try this
    SERIN2 PORTC.7, 16468,100, error, [WAIT("hello")]
    The above will wait for 100 milliseconds, then GOTO "error" if "hello" is not received.
    Oct 2008
    Red face
    Hi mackrackit, thanks for the help, appreciated very much. I manage to run this code MCU to PC and use this guide http://melabs.com/resources/ser2modes.htm
    SERIN2 PORTC.7, 84,200, error, [WAIT("Hello")]
    serout2 PortC.6,84, ["Valid",10,13]
    error:
    serout2 PortC.6, 84, ["Invalid",10,13]
    I know u have given me an example, but dont really get it ,
    Is there a way I could receive this value "$GPRMC,053740.000" and place it on a variable?
    thanks and regards,
    mbox
        H       VAR BYTE 'HOURS
        M       VAR BYTE 'MINUTES
        S       VAR BYTE 'SECONDS
    [WAIT("$GPRMC"),WAIT(","),DEC2 H,DEC2 M,DEC2 S]
    Waits for GPRMC
    Waits for ","
    Places the first two digits into VAR H
    Places the middle two digits into VAR M
    Places the last two digits into VAR S
    "$GPRMC,053740.000"
    053740 =
    H = 05 Hours
    M = 37 Minutes
    S = 40 Seconds
    If you have not seen this it might be handy
    http://aprs.gids.nl/nmea/
    SWITZERLAND (french speaking)
    Default TIMEOUT issue
    Be careful while using TIMEOUT - you may get fuzzy results.
    Have a look here http://www.picbasic.co.uk/forum/show...1443#post91443.
    Roger
    Oct 2008
    Hi, thanks for the tip, it sure did saved me from trouble
    regards,
    mbox
    Oct 2008
    Thumbs up
        H       VAR BYTE 'HOURS
        M       VAR BYTE 'MINUTES
        S       VAR BYTE 'SECONDS
    Waits for GPRMC
    Waits for ","
    "$GPRMC,053740.000"
    053740 =
    H = 05 Hours
    M = 37 Minutes
    S = 40 Seconds
    Thanks so much mackrackit.
    regards,
    mbox
    Oct 2008
    Hi, I want to try to use 38400 baud rate with 20Mz crystal. I want to test it first in the hyperterminal by entering this line "$GPGGA,115209.600,1114.5166,N,12500.3439,E,1,10,0 .83,16.9,M,55.4,M,,*5E" and I use this code
    DEFINE HSER_SPBRG 32 ' 38400 Baud @ -1.36%
    define HSER_BAUD 38400
    define OSC 20
    gpsin var portc.7 'rx
    gpsout var portc.6 'tx
    HH VAR byte
    MM VAR BYTE
    SS VAR BYTE
    ND VAR BYTE
    NM VAR BYTE
    NMD VAR WORD
    WD VAR BYTE
    WM VAR BYTE
    WMD VAR WORD
    AR VAR BYTE[20]
    START:
    SERIN2 gpsin,16572,[WAIT("$GPGGA"),WAIT(","),DEC2 hH,DEC2 mM,DEC2 sS,_
    PAUSE 1000
    SEROUT2 gpsin,16572,[DEC2 HH,DEC2 MM,DEC2 SS,_
    DEC2 ND,DEC2 NM,DEC3 NMD,DEC3 WD,DEC2 WM,DEC3 WMD,13,10]
    goto START
    but I dont have any display on the recieve window. Please help..
    regards,
    mbox
    Get rid of the above. You are not using the hardware with SERIN2
    It looks like you have not quite decided whether to use the hardware serial port, or serin2/serout2. Once you decide which one you are using, you may have better luck. Let us know how it goes.
    EDIT: Once again, beaten by Dave....
    Oct 2008
    Hi, I was happy when I got the GPS set to 9600 but yesterday I found out that it reset itself to 57600. I tried to reset it back to 9600 but failed and I tried it the whole afternoon...I use this as my reference http://www.laptopgpsworld.com/3701-d...ocosys-ls20031 it can only lowered to 38400, so I have no choice but to try this baudrate. My first time to use 20Mz crystal. I'm showing my codes when the GPS was running fine in 9600 baudrate. Please forgive my codings, still learning
    clear
    H VAR BYTE[2]
    TRISD = %00000000 ' PortD.0 LCD connection
    TRISC = %10000000 ' PortC.6 as tx and PortC.7 as rx
    TRISB = %00000001	' PortB.0 as rx from GPS
    PortB =  %00000000
    PortD =  %00000000
    'This following serout2 command is use for bluetooth initialization
     SerOut2 PortC.6,84, [$02,$52,$27,$06,$00,$7F,$12,$13,$23,$17,$09,$00,$03]
     pause 200
     SerOut2 PortC.6,84, [$02,$52,$66,$00,$00,$B8,$03]
     pause 200
     Serout2 PortC.6,84, [$02,$52,$04,$11,$00,$67,$10,$4D,$49,$43,$52,$4F,$42,$4F,$58,$42,$54,$31,$20,$20,$20,$20,$00,$03]
     RX var byte ' Receive byte
     serout PortD.0,T9600,[$1B,$45]
     serout PortD.0,T9600,["Loging on.."]
     pause 300
     ''Main Code
     Pause 1000
     serout PortD.0,T9600,["**GPS Locator**"]
     Menu:
     pause 200
     '****** [Menu setup on PC screen] *************************
     serout PortD.0,T9600,[$1B,$45,"**System Ready**"]
     Receive:
     ' ***** [Receive the menu selection from Bluetooth receiver] ***************
     serin PortC.7, T9600, RX 'Receive menu from Bluetooth
     'serout PortD.0,T9600,[$D,RX]    'Check Input
     RX = RX - $30 'Convert ASCII to decimal value
     If RX > 1 then Error ' Test for good value
     Branch RX, [zero, one] 'redirect to menu selection code
     error:
     serout2 PortC.6, 84, ["Oops Try again ",#RX,10,13]
     goto menu
     Zero:
     '***** [ Code for zero value ] *****************************
     goto menu 'Return to menu, zero is not a  valid selection
     One:
    '***** [Code for selection 1] ************************
    ;serout PortD.0,T9600,[$D,"Request ",#rx]
    ;serout PortD.0,T9600,[$1B,$45,"**System Ready**"]
    ;serout PortD.0,T9600,[$D,"Data sent"]
    SERIN2 PORTB.0, 84,40, error,[WAIT("$GPRMC"),WAIT("A,"),str H\24]
    serout2 PortC.6, 84, [str H\24,10,13] 'Send data to bt
    ' example output: 1114.5089,N,12500.3864,E
    goto menu 'Return to main menu
    goto menu
    Please help me make it run to 38400 baudrate, I have the 20Mz crystal.
    thanks in advance,
    mbox
    Oct 2008
    I am trying to run this code...
    define OSC 20
    HH VAR byte
    MM VAR BYTE
    SS VAR BYTE
    ND VAR BYTE
    NM VAR BYTE
    NMD VAR WORD
    WD VAR BYTE
    WM VAR BYTE
    WMD VAR WORD
    AR VAR BYTE[20]
    START:
    PAUSE 1000
    SEROUT2 gpsout,16572,[DEC2 HH,DEC2 MM,DEC2 SS,_
    goto start
    I'm testing PC to MCU first, but I don't have response when entering $GPGGA,114708.600,1114.5089,N,12500.3864,E,1,6,1.6 7,23.5,M,55.4,M,,*69
    regards,
    mbox
    Oct 2008
    Post
    I manage to run this code for a start
    @ DEVICE HS_OSC
    DEFINE    OSC 20
    serout2 PortC.6,32774,["To PC",$D]  ;@38400 To PC
    serout2 PortB.6,84,[$1B,$45]
    serout2 PortB.6,84,["To LCD"] ;@9600 To Lcd
    I will update my codes with the Gps, and post it here later...
    regards,
    mbox
    That is more like it.
    Start small and build your way up
    Oct 2008
    I'm trying to add two numbers, 1st number is 140000 and the 2nd is 5377 which will give me 145377. And after getting the sum it will be divided by 60. x= (140000+ 537)/60, I think WORD can not hold much of the integers I need.
    Ho do I do this in PBP?
    You are right, a word only goes up to 65535. If you have PBP v 2.5 or later, (and were using a PIC18 chip) you could select to use PBPL to compile, and define your large variables as LONG instead of WORD.
    If you want to stick with the PIC16 series, you could use N-BIT math. http://www.picbasic.co.uk/forum/cont...153-N-Bit_MATH
    By the way, it looks like you are using PM as your assembler.
    @ DEVICE HS_OSC
    You probably need to use MPASM for N-Bit Math to work. For that, you define your configs like this:
    @ __config _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF
    But you must comment out the configs in you C:/PBP/16F877A.INC file.
    See : http://www.picbasic.co.uk/forum/cont...o-your-Program
    Oct 2008
    Hi scalerobotics, I got my setup using Mpasm, and trying to figure out how Darrel's N-Bit_Math works, I need a sample to study its output. Try to use wozzy's code in pic16f877A
    PRECISION CON 8 SYSTEM  	' 8 bytes = 64-bit
    INCLUDE "N-Bit_Math.pbp"	' Include Alexander Avtanski's Multibyte Arithmetic
    				' Assembly Library Wrapped for PBP by Darryl Taylor
    				' Version:1.3 Beta (1/7/2010)
    ;@ DEVICE HS_OSC
    DEFINE OSC 20			' 20 MHz Crystal Oscillator
    DEFINE DEBUG_REG PORTC		' PORT C6
    DEFINE DEBUG_BIT 6 			' PORT C6
    DEFINE DEBUG_BAUD 57600		' BAUD 57600
    DEFINE DEBUG_MODE 0 		' 1 = inverted, 0 = true
    I			VAR	BYTE
    AA64 		VAR BYTE[PRECISION]
    BB64		VAR BYTE[PRECISION]
    CC64     	VAR BYTE[PRECISION]
    DD64		VAR BYTE[PRECISION]
    XX64		VAR BYTE[PRECISION]
    YY64		VAR BYTE[PRECISION]
    ZZ64		VAR BYTE[PRECISION]
    PAUSE 500 : DEBUG "   ",10,13,10,13 : PAUSE 500
    MAIN:
    	@  MATH_MUL  _AA64, _BB64, _XX64	; @  MATH_MUL  _A, _B, _Res ; Res = A / B - Remainder in REG_Z
    	@  MATH_DIV  _CC64, _DD64, _YY64	; @  MATH_DIV  _A, _B, _Res ; Res = A / B - Remainder in REG_Z
    	@  MATH_DIV  _DD64, _CC64, _ZZ64	; @  MATH_DIV  _A, _B, _Res ; Res = A / B - Remainder in REG_Z
    	DEBUG "BYTE ORDER BYTE[7],BYTE[6],BYTE[5],BYTE[4],BYTE[3],BYTE[2],BYTE[1],BYTE[0]",10,13,10,13
    	DEBUG "AA64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 AA64[I] : NEXT I : DEBUG 10,13
    	DEBUG "BB64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 BB64[I] : NEXT I : DEBUG 10,13
    	DEBUG "CC64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 CC64[I] : NEXT I : DEBUG 10,13
    	DEBUG "DD64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 DD64[I] : NEXT I : DEBUG 10,13
    	DEBUG "XX64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 XX64[I] : NEXT I : DEBUG 10,13
    	DEBUG "YY64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 YY64[I] : NEXT I : DEBUG 10,13
    	DEBUG "ZZ64 = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 ZZ64[I] : NEXT I : DEBUG 10,13
    	DEBUG "REG_Z = " : FOR I = 7 to 0 Step -1 : DEBUG BIN8 REG_Z[I] : NEXT I : DEBUG 10,13
    	DEBUG 10,13,10,13,10,13,10,13
    	PAUSE 10000
    GOTO MAIN
    I don't have any display on the hyper terminal window, My first time to encounter DEBUG command, but I think its similar to Serout2, is not it?
    regards,
    mbox
    is this still part of the GPS project or something new?
    Either way, where are the numbers coming from?
    Oct 2008
    Yes it's part of the GPS. Google map can interpret this "11 14.5377,125 00.3560". But for my Mobile map application it can not, it reads this format "11.242295, 125.005933", I will explain my alternative solution only for th the latitude part using data "$GPRMC,115209.200,A,1114.5377,N,12500.3439,E,0.02 ,296.54,021110,,,A*65", I extract data to this format "Deg 11 Min 14 Sec 5377". Then I need 14 and 5377 to be this 145377 format (my alternative solution is to 14x10000+5377) then divide it by 60 which will give me 2422.95. I need to make it whole number so 2422.95 x 100 = 242295. Then format the data to this deg 11.242295 ans send it to PortC.6, 11 is the degree and add a "." in between. Any alternative solution would be nice.
    regards,
    mbox
    Not quite the accuracy you want but it is close. Maybe someone else can get it closer.
    This returns 2422.
        K   CON 10000
        MINS VAR BYTE
        SECS VAR WORD
        MINS = 14
        SECS = 5377
        Y   VAR WORD
        Z   VAR WORD     'DUMMY VAR
        Z1  VAR WORD     'DUMMY VAR
        START:
        SECS = SECS / 10
        Z = (MINS * K)
        Z1 = DIV32 10
        Y = Z1 + SECS
        Z = (Y / 6)
        LCDOUT $FE,1,"Z= ",DEC Z
    Default minutes and seconds to degrees
    Hey Mbox,
    I think you are close, but your degrees calculation is a little off (if I am right about you converting minutes and seconds to degrees). I know a short cut, if you can live without decimal seconds.
    Say you want to convert 11 deg 14 min and 53.77 seconds to degrees. If you can live without decimal seconds, we have 11 deg 14 min and 54 seconds. To convert to degrees.degrees:
    to convert minutes to degrees
    (14 * 500)/3 = 2333 (really .2333 degrees)
    and now convert seconds
    (54 * 50)/18 = 150 (really .015 degrees)
    2333
    +150
    =2483
    or 11.2483 degrees. This result fares well with http://www.satsig.net/degrees-minute...calculator.htm , which says the result should be 11.24827 using the seconds decimals.
    So with two variables you could store the result. lon_hi would = 11 and lon_low would = 2483. If you need to turn this out the serial port, your code can also place the decimal point between them.
    Oct 2008
    Hi everyone, thanks for the inputs appreciated it very much...I will make tests and see the results regarding the calculation part. So far I made 30 queries by sms from the device and works okay without yet the format and calculation I desire in the mcu, right now the calculation are done and formatting within the mobile codings. I'll be away for 3 days, hopefully by end of the week I can smoothen it more.
    Technos: PBP 2.50 and Python for the mobile app.
    regards,
    mbox
    Last edited by mbox; - 8th November 2010 at 23:25. Reason: Sorry I settle to send 1 pic only, I will add more later if updates are completed.
