Compiler Warning messages
Results 1 to 8 of 8
    Pedro Pinto's Avatar
    Pedro Pinto Guest
    Default 18F4520 and used last Darrel Taylor DS_INT18 update
    Hello
    My programm run on 18F4520 and used last Darrel Taylor DS_INT18 update
    After compiling it shows the above messages
    What make i wrong or how can i solve this?
    Apreciate any help
    Compiler 2.50 and on vesion 2.60 the same messages
    Best regards
    Pedro
    Message[301] c:compil~1\sc8406~2.asm 1617 : MESSAGE: (Temp variables exceeding T7)
    '''refer to this lines of the generated asm file
    ifdef T7
    MOVE?WW _T7_SaveH, T7
    if (PBPLongs_Used == 1)
    MOVE?WW _T7_SaveH+2, T7+2
    ifdef T8
    ifndef NO_T7_WARNING
    messg "Temp variables exceeding T7"
    Warning[207] c:compil~1\sc8406~2.asm 1638: Found label after column 1.(INT_LST)
    INT_LIST macro
    INT_Handler RX_INT, _IntRx, PBP, yes
    INT_CREATE
    In assembly language, indentation is critical.
    We can't tell how you've indented your code unless you put it in [code][/code] tags.
    But when it tells you "Found label after column 1.(INT_LST)" ...
    It usually means it's not in column 1 (indented).
    Pedro Pinto Guest
    Hello Darrel
    Have arranged the code, and now not show the message anymore
    But the message MESSAGE: (Temp variables exceeding T7) continue
    Is this a Interrupt DS_INT problem?
    Best regards
    Pedro
    It means that you have very long math formulas or IF statements in your program that is creating a lot of system Temp variables.
    If they are not in your interrupts handler, then add
    DEFINE NO_T7_WARNING 1
