programming DDS core
Results 1 to 10 of 10
    PBP doesn't have decimals, and (2^32 * 10e6) takes more than 32-bit LONGs.
    But using some 64-bit math works out pretty good.
    With the N-Bit_Math module from ... http://www.picbasic.co.uk/forum/showthread.php?t=12433
    <font color="#000000"><b>PRECISION  </b><font color="#008000"><b>CON </b></font><font color="#800000"><b>8 </b></font><b>SYSTEM         </b><font color="#0000FF"><b><i>' 8 bytes = 64-bit
    </i></b></font><font color="#008000"><b>INCLUDE </b></font><font color="#FF0000">&quot;N-Bit_Math.pbp&quot;
    </font><b>Base  </b><font color="#008000"><b>VAR BYTE</b></font>[<b>PRECISION</b>]
    <b>Fo    </b><font color="#008000"><b>VAR BYTE</b></font>[<b>PRECISION</b>]
    <b>Fs    </b><font color="#008000"><b>VAR BYTE</b></font>[<b>PRECISION</b>]
    <b>FTW   </b><font color="#008000"><b>VAR BYTE</b></font>[<b>PRECISION</b>]
    <font color="#008000"><b>ASM
       </b></font><font color="#000080">MOVE?CP  4294967295, _Base    </font><font color="#0000FF"><b><i>; 2^32 - 1
       </i></b></font><font color="#000080">MOVE?CP  10000000, _Fo        </font><font color="#0000FF"><b><i>; desired frequency out
       </i></b></font><font color="#000080">MOVE?CP  360000000, _Fs       </font><font color="#0000FF"><b><i>; DDS clock
       </i></b></font><font color="#000080">MATH_MUL _Base, _Fo, _FTW     </font><font color="#0000FF"><b><i>; 2^32 * Fo
       </i></b></font><font color="#000080">MATH_DIV _FTW, _Fs, _FTW      </font><font color="#0000FF"><b><i>; / Fs
    </i></b></font><font color="#008000"><b>ENDASM
    HSEROUT </b></font>[<font color="#FF0000">&quot; FTW=&quot;</font>,<font color="#008000"><b>HEX2 </b></font><b>FTW</b>(<font color="#800000"><b>3</b></font>),<font color="#008000"><b>HEX2 </b></font><b>FTW</b>(<font color="#800000"><b>2</b></font>),<font color="#008000"><b>HEX2 </b></font><b>FTW</b>(<font color="#800000"><b>1</b></font>),<font color="#008000"><b>HEX2 </b></font><b>FTW</b>(<font color="#800000"><b>0</b></font>),<font color="#800000"><b>13</b></font>,<font color="#800000"><b>10</b></font>]
    <font color="#008000"><b>STOP
    </b></font>
    Which shows a result of ...
    FTW=071C71C7
    Which is the hex value for 119,304,647
    The value is located in the lower 4 bytes of the FTW array and can be easily shifted out to the DDS.
    HTH,
    Sep 2005
    France
    Lightbulb
    WOW ! It works !
    Thank You Darrel
    Sep 2005
    France
    But... I have tried to use a variable for Frequency output and it doesn't work anymore...
    PRECISION  CON 8 SYSTEM         ' 8 bytes = 64-bit
    INCLUDE "N-Bit_Math.pbp"
    define osc 4
    FOUT    var LONG
    Base  VAR BYTE[PRECISION]
    Fo    VAR BYTE[PRECISION]
    Fs    VAR BYTE[PRECISION]
    FTW   VAR BYTE[PRECISION]
    high portc.6
    FOUT = 1000000
       MOVE?CP  4294967295, _Base    ; 2^32 - 1
       MOVE?CP  _FOUT, _Fo        ; desired frequency out
       MOVE?CP  360000000, _Fs       ; DDS clock
       MATH_MUL _Base, _Fo, _FTW     ; 2^32 * Fo
       MATH_DIV _FTW, _Fs, _FTW      ; / Fs
    serout2 portc.6,84,[" FTW=",HEX2 FTW(3),HEX2 FTW(2),HEX2 FTW(1),HEX2 FTW(0),13,10]
    STOP
    MOVE?CP is for constants.
    Use MOVE?LP for LONG variables.
    Sep 2005
    France
    Darrel... you're wonderful !
    ADDED:
    Since you are using PBPL, you can also move the result back to a LONG...
    FOUT    var LONG
    FTWL  VAR LONG
    high portc.6
    FOUT = 10000000
       MOVE?LP  _FOUT, _Fo           ; desired frequency out
       MOVE?PL  _FTW, _FTWL          ; move result to a LONG var
    serout2 portc.6,84,[" FTW=",HEX8 FTWL," = ",DEC FTWL,13,10]
    STOP
