A little DT_INT confusion.
Results 1 to 7 of 7
    Dec 2008
    Los Angeles, CA
    Angry
    It's a PIC18F2520.
    I was going to run the risk of talking to myself, and add another short bit - I finally got smart, and put something in the main loop, so I could see if the uart interrupt handler ever returned from it's job, and found that it isn't!!
    Everything just appears to stop after a uart interrupt. It does what it's suppose to, (reads from one port, and writes to the other) and never returns to the main loop.
    I'm at a loss, and hoping that would be of some help.
    'INITIALIZE INTERRUPTS
    INT_LIST  MACRO       ;IntSource,Label,Type,ResetFlag?
            INT_Handler INT2_INT, _EXTTS,PBP,yes
            INT_Handler RX_INT, _RDRINT,PBP,yes
        ENDM
        INT_CREATE                               ;CREATES THE INTERRUPT PROCESSOR
    START:
    GOSUB CLS
    PAUSE 100
    SEROUT2 DIAGOUT,MODE,["SDIF2 VER. 1",10,13]
    'ENABLE INTERRUPTS
    @ INT_ENABLE RX_INT                          ;READER UART INTERRUPT
    @ INT_ENABLE INT2_INT                        ;EXTERNAL INTERRUPT
    MAIN:
    SEROUT2 DIAGOUT,MODE,["."]
    FOR X=1 TO 100
         PAUSE 1
    NEXT X
    GOTO MAIN
    RDRINT:                                      'TAG READER INTERRUPT!
    HSERIN [WAIT($02),STR TAG\8\$03]             'READ TAG FROM THIS PORT      (WORKS)
    SEROUT2 DIAGOUT,MODE,[STR TAG,10,13]         'SEND TAG DATA TO THIS PORT   (WORKS)
    @ INT_RETURN                                 ; <=== THIS IS NOT RETURNING! (DOES NOT WORK)
    EXTTS:
    'SEND SPECIAL DATA NOW
    SEROUT2 DIAGOUT,MODE,["00995031",10,13]      '(WORKS)
    @ INT_RETURN                                 ;(WORKS)
    Dec 2008
    Los Angeles, CA
    Dave! You nailed it. I don't know how you remember/find all these links!!
    I changed the Uart interrupt to this, and it now works:
    While PIR1.5 = 1     ; clear the buffer
        HSERIN [X]
    Wend
    @ INT_RETURN                                 ; <=== NOW WORKING :-)
    I want to really look up what that is doing now, and write a note or two. THANK YOU.
    Len
