A little DT_INT confusion.
Results 1 to 7 of 7
    Dec 2008
    Los Angeles, CA
    Default A little DT_INT confusion.
    I'm still a little new to DT_INTs, and am having a little trouble. I'm trying to use two interrupts, one on a hardware UART, and the second using Ext Int 2. The hardware uart is reading an RFID tag and goes on to just send the data out the debug port.
    Ext Int 2 is simply a wire that, when grounded, should write some fake RFID data to my TAG string, and send that out the debug port as well.
    If the External interrupt goes first, it works ONCE; but after the UART interrupt works, the data that was put in the data string is only transmitted AFTER the next data read by the uart!!
    I am at a loss to understand what's happening here. Can somebody see my goof/s?
    'INCLUDE FILES FOR DT INTERRUPTS
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    'CONSTANTS
    MODE      CON  6                             'SERIN2/SEROUT2 TO USE 38400 BAUD
    'VARIABLES
    TP1       VAR  PORTA.0                       'TP1 (GC SIDE)
    TP2       VAR  PORTA.1                       'TP2 (GC SIDE)
    TP3       VAR  PORTA.2                       'TP3 (READER SIDE)
    LED       VAR  PORTA.3                       'ACTIVITY LED
    ITP0      VAR  PORTA.5                       'INTERNAL TEST POINT 0
    DAV       VAR  PORTA.6                       'DAV (INT) FLAG TO GC
    DATA0     VAR  PORTB.0                       'WIEGAND INPUT
    DATA1     VAR  PORTB.1                       'WIEGAND INPUT
    EXTINT    VAR  PORTB.2                       'TERMINAL STRIP INTERRUPT
    LEDR      VAR  PORTB.3                       'RED LED
    LEDG      VAR  PORTB.4                       'GRN LED
    BUZZ      VAR  PORTB.5                       'BUZZER
    ITP1      VAR  PORTC.0                       'INTERNAL TEST POINT 1
    ITP2      VAR  PORTC.1                       'INTERNAL TEST POINT 2
    DIAGIN    VAR  PORTC.2                       'DIAG IN (DEBUGIN)
    DIAGOUT   VAR  PORTC.3                       'DIAG OUT (DEBUG)
    X         VAR  BYTE
    Y         VAR  BYTE
    Z         VAR  BYTE
    TAG       VAR  BYTE[10]
    CLEAR
    'INITIALIZE INTERRUPTS
    INT_LIST  MACRO                              ;IntSource,Label,Type,ResetFlag?
            INT_Handler INT2_INT, _EXTTS,PBP,yes
            INT_Handler RX_INT, _RDRINT,PBP,yes
        ENDM
        INT_CREATE                               ;CREATES THE INTERRUPT PROCESSOR
    'ENABLE INTERRUPTS
    @ INT_ENABLE RX_INT                          ;READER UART INTERRUPT
    @ INT_ENABLE INT2_INT                        ;EXTERNAL INTERRUPT
    MAIN:
    PAUSE 1
    GOTO MAIN
    RDRINT:                                      'TAG READER INTERRUPT!
    HSERIN [WAIT($02),STR TAG\8\$03]             'READ ENTIRE TAG
    GOSUB SHOW                                   'SEND TAG/KEYPAD DATA TO DIAG PORT
    GOSUB ERASETAG
    @ INT_RETURN
    EXTTS:
    'WRITE TAG DATA HERE:
    '00995031
    TAG[0]=$30:TAG[1]=$30:TAG[2]=$39:TAG[3]=$39:TAG[4]=$35:TAG[5]=$30:TAG[6]=$33:TAG[7]=$31
    GOSUB SHOW
    GOSUB ERASETAG
    @ INT_RETURN
    SHOW:
    'SHOW TAG CHARACTERS:
    SEROUT2 DIAGOUT,MODE,[STR TAG,10,13]         'SEND DATA TO DIAG PORT
    ERASETAG:                                    'ERASE DATA
    FOR Z=0 TO 10
         TAG[Z]=$00
    NEXT Z
    A couple of things that might be causing the trouble.
    You have TAG defined as ten elements but you erase 11
    FOR Z=0 TO 10
    Try removing the WAIT in the HSERIN statement. Triggers once then it has to WAIT for the second time data is sent to move on....
    And I do not see where the USART is set up?
    You may want to read over this
    http://www.picbasic.co.uk/forum/show...3530#post23530
    Dec 2008
    Los Angeles, CA
    I will fix the TAG error as soon as I get to work, and check on the WAIT also. Either interrupt works fine by itself, but not both together. I'll let you know if the WAIT fixed anything. The serial port is set up ok, I just thought the code was getting kind of long to post. Thanks for the reply!
    Dec 2008
    Los Angeles, CA
    Unhappy
    I simplified things somewhat to try to isolate my error, but I'm not finding it.
    After the UART interrupt is used, the INT2 interrupt will not send it's data until AFTER the NEXT uart interrupt!! I'm lost.
    'PORT SETUPS
         ;PORT A
         CLRF PORTA
         MOVLW 07h
         MOVWF ADCON1                            ;A/D'S OFF
         MOVWF 07h
         MOVWF CMCON                             ;COMPARATORS OFF
         MOVLW 00000000b                         ;PIN DIRECTION PORT A
         MOVWF TRISA
         ;PORT B
         CLRF PORTB
         MOVLW 0Fh
         MOVLW 11000111b                         ;PIN DIRECTION PORT B
         MOVWF TRISB
         ;PORT C
         CLRF PORTC
         MOVLW 10011000b                         ;PIN DIRECTION PORT C
         MOVWF TRISC
    'SET REGISTERS
    INTCON2.7=0                                  'PORT B PULLUPS ON (0=ON)
    INTCON2.6=0                                  'INT0 TRIGGERS ON FALLING EDGE
    INTCON2.5=0                                  'INT1 TRIGGERS ON FALLING EDGE
    INTCON2.4=0                                  'INT2 TRIGGERS ON FALLING EDGE
    'DEFINES
    DEFINE OSC 20
    DEFINE HSER_RCSTA 90h                        'Enable serial port & continuous receive
    DEFINE HSER_TXSTA 24h                        'Enable transmit, BRGH = 1
    DEFINE HSER_CLROERR 1                        'Clear overflow automatically
    DEFINE HSER_SPBRG 8                          '9600 Baud @ 20MHz, -0.03%
    SPBRGH = 2
    BAUDCON.3 = 1                                'Enable 16 bit baudrate generator
    'DEBUG PORT (Group Controller)
    DEFINE DEBUG_REG PORTC                       'DEBUG PIN IS IN PORT C
    DEFINE DEBUGIN_REG PORTC                     'DEBUGIN PIN IS IN PORT C
    DEFINE DEBUG_BIT 5                           'DEBUG TRANSMIT PORT C5
    DEFINE DEBUGIN_BIT 4                         'DEBUG RECEIVE PORT C4
    DEFINE DEBUG_BAUD 57600                      '57600 BAUD TO GC
    DEFINE DEBUG_MODE 0                          'INVERTED OUTPUT (COMPENSATE FOR MAX232)
    'CONSTANTS
    'VARIABLES
    FLAG      VAR  BIT
    X         VAR  BYTE
    Y         VAR  BYTE
    Z         VAR  BYTE
    TAG       VAR  BYTE[11]
    CLEAR
        ENDM
    'ENABLE INTERRUPTS
    @ INT_ENABLE RX_INT                          ;UART INTERRUPT
    @ INT_ENABLE INT2_INT                        ;EXT INT 2
    MAIN:
    FOR X=1 TO 1000
         PAUSEUS 100
    NEXT X
    GOTO MAIN
    HSERIN [STR TAG\9\$03]
    FOR Z=0 TO 10
         TAG[Z]=$00
    NEXT Z
    @ INT_RETURN
    EXTTS:
    SEROUT2 DIAGOUT,MODE,["00995031",10,13]
    @ INT_RETURN
    I am not sure where the problem is either.
    Maybe it has something to do with setting the interrupt registers before the instants are enabled. Darrel.s routine sets these so you do not need to do it.
    Reading through other post this seems similar (post 52 and 53). I am sure you have read them but it is all I can find at the moment.
    http://www.picbasic.co.uk/forum/show...3402#post23402
    And I think this is related
    http://www.picbasic.co.uk/forum/show...=9786#post9786
    Did you say what PIC you are using?
    Dec 2008
    Los Angeles, CA
    Angry
    It's a PIC18F2520.
    I was going to run the risk of talking to myself, and add another short bit - I finally got smart, and put something in the main loop, so I could see if the uart interrupt handler ever returned from it's job, and found that it isn't!!
    Everything just appears to stop after a uart interrupt. It does what it's suppose to, (reads from one port, and writes to the other) and never returns to the main loop.
    I'm at a loss, and hoping that would be of some help.
        ENDM
    START:
    GOSUB CLS
    PAUSE 100
    SEROUT2 DIAGOUT,MODE,["SDIF2 VER. 1",10,13]
    'ENABLE INTERRUPTS
    MAIN:
    SEROUT2 DIAGOUT,MODE,["."]
    FOR X=1 TO 100
         PAUSE 1
    NEXT X
    GOTO MAIN
    HSERIN [WAIT($02),STR TAG\8\$03]             'READ TAG FROM THIS PORT      (WORKS)
    SEROUT2 DIAGOUT,MODE,[STR TAG,10,13]         'SEND TAG DATA TO THIS PORT   (WORKS)
    @ INT_RETURN                                 ; <=== THIS IS NOT RETURNING! (DOES NOT WORK)
    EXTTS:
    'SEND SPECIAL DATA NOW
    SEROUT2 DIAGOUT,MODE,["00995031",10,13]      '(WORKS)
    @ INT_RETURN                                 ;(WORKS)
