Erratic Behavior on a 18F452
Results 1 to 5 of 5
    Ohio
    Default Erratic Behavior on a 18F452
    I am using an 18F452 micro, running at 20 MHz’s. I have four 22k resistors, one each connected in series with pins RA0 thru RA3 with a 5 volt Zener diode clamping the voltage at each of the pins to 5 volts. I am supplying 12 volts to these four 22k resistors from a Hall Effect sensor array under the turret on my lathe. Depending on what position the turret is in will give me 0 or 12 volts on these pins which I use to tell what tool is being used. The problem I’m having is, when I connect these four wires to my circuit board I get erratic behavior on the turret. It loses turret position plus most of the time of I cannot upload the program to the micro using the bootloader. If I unhook these four wires everything is happy again. The only thing I can think of that might be the problem is, maybe there is something else needed to deactivate the analog portion of the micro. I have the line ADCON1 = 7 at the top of my code already. Is there something else I’m missing?
    Mark
    Quote Originally Posted by markcadcam View Post
    I am using an 18F452 micro, running at 20 MHz’s. I have four 22k resistors, one each connected in series with pins RA0 thru RA3 ...
    Mark
    Hi, Mark
    provide us a little FULL SCHEME of your thing, plus your DETAILED CONFIG. Header ...
    the clearer the scheme, the better the explanations ...
    Ohio
    Attached is my code.
    '* Name: HNC Turret Controller.BAS *
    '* Started: 11/29/08 *
    '* Micro: 18F452 *
    '* Updated 10/8/2010 *
    '* Serial Input *
    ADCON1 = 7 'set I/O pins to digital on PORT.A
    define OSC 20
    Include "modedefs.bas"
    input PORTA.0
    INPUT PORTA.1
    INPUT PORTA.2
    INPUT PORTA.3
    input PORTA.4
    INPUT PORTC.2
    output PORTD.2
    OUTPUT PORTD.3
    output PORTD.0
    OUTPUT PORTC.3
    OUTPUT PORTD.1
    B0 var byte
    ToolToChangeTo var Byte
    Speed var word
    StepCount var LONG
    HomeSpeed var word
    SlowHome var word
    i var long 'was WORD
    CurrentTool var byte
    ToolSlotsToMove var long
    RequestedTool var byte
    StepsToMove var long
    StepsToMoveForEachTool var long ' Steps per tool move
    ToolToChangeTo = 0 'zero variable
    Speed = 30 ' was 30
    StepCount = 0
    CurrentTool = 0
    StepsToMoveForEachTool = 7500
    RequestedTool = 0
    StepsToMove = 0
    ToolSlotsToMove = 0
    i = 0
    HomeSpeed = 250
    SlowHome = 350
    B0 = 0
    PORTD.2 = 1
    PORTD.1 = 0
    PORTD.3 = 0 ' turret cylinder out
    B0 = 0
    Serin PORTC.2,T9600,["AB"], # B0
    ToolToChangeTo = B0
    PORTD.2 = 0 'Pause Deskcnc
    DoToolChange:
    iF tOOLtOcHANGEtO = 1 tHEN
    goto AutoTool1
    iF tOOLtOcHANGEtO = 2 tHEN
    goto AutoTool2
    iF tOOLtOcHANGEtO = 3 tHEN
    goto AutoTool3
    iF tOOLtOcHANGEtO = 4 tHEN
    goto AutoTool4
    iF tOOLtOcHANGEtO = 5 tHEN
    goto AutoTool5
    iF tOOLtOcHANGEtO = 6 tHEN
    goto AutoTool6
    iF tOOLtOcHANGEtO = 7 tHEN
    goto AutoTool7
    iF tOOLtOcHANGEtO = 8 tHEN
    goto AutoTool8
    If ToolToChangeTo = 10 Then ' use tool 10 to home turret
    Goto HomeTurret
    Endif
    AutoTool1: If PORTA.0 = 0 and PORTA.1 = 0 and PORTA.2 = 0 and PORTA.3 = 1 then
    PORTD.2 = 1 ' UnPause DeskCNC Controller
    Else
    RequestedTool = 1
    Gosub IndexTurret
    Repeat
    Until PORTA.4 = 0
    Goto main
    AutoTool2: If PORTA.0 = 0 AND PORTA.1 = 0 AND PORTA.2 = 1 AND PORTA.3 = 0 THEN
    eLSE
    RequestedTool = 2
    Gosub IndexTurret
    Repeat
    Until PORTA.4 = 0
    AutoTool3: If PORTA.0 = 0 AND PORTA.1 = 0 AND PORTA.2 = 1 AND PORTA.3 = 1 THEN
    RequestedTool = 3
    Gosub IndexTurret
    Repeat
    Until PORTA.4 = 0
    AutoTool4: If PORTA.0 = 0 AND PORTA.1 = 1 AND PORTA.2 = 0 AND PORTA.3 = 0 THEN
    RequestedTool = 4
    Gosub IndexTurret
    Repeat
    Until PORTA.4 = 0
    AutoTool5: If PORTA.0 = 0 AND PORTA.1 = 1 AND PORTA.2 = 0 AND PORTA.3 = 1 THEN
    RequestedTool = 5
    Gosub IndexTurret
    Repeat
    Until PORTA.4 = 0
    AutoTool6: If PORTA.0 = 0 and PORTA.1 = 1 and PORTA.2 = 1 and PORTA.3 = 0 then
    RequestedTool = 6
    Gosub IndexTurret
    Repeat
    Until PORTA.4 = 0
    AutoTool7: If PORTA.0 = 0 AND PORTA.1 = 1 AND PORTA.2 = 1 AND PORTA.3 = 1 THEN
    RequestedTool = 7
    Gosub IndexTurret
    Repeat
    Until PORTA.4 = 0
    AutoTool8: If PORTA.0 = 1 AND PORTA.1 = 0 AND PORTA.2 = 0 AND PORTA.3 = 0 THEN
    RequestedTool = 8
    Gosub IndexTurret
    Repeat
    Until PORTA.4 = 0
    HomeTurret:
    High PORTD.1 ' Turn on air valve to lift turret
    Repeat
    Until PORTA.4 = 1 ' wait for turret to lift and trigger limit switch
    Repeat ' rotate turret until position tool #1 is reached
    high PORTC.3 ' move forward (Direction pin on servo is high)
    high PORTD.0
    pauseus Homespeed
    low PORTD.0
    pauseus Homespeed
    until PORTA.0 = 0 and PORTA.1 = 0 and PORTA.2 = 0 and PORTA.3 = 1
    for i = 1 to 5000
    low PORTC.3 ' move in reverse to back off of hall effect sensor tool #1
    high PORTD.0
    pauseus Homespeed
    low PORTD.0
    pauseus Homespeed
    next
    Repeat ' rotate turret until position tool #1 hall effect sensor is reached
    high PORTD.0
    pauseus SlowHome
    low PORTD.0
    pauseus SlowHome
    for i = 1 to 5000
    high PORTD.0
    pauseus SlowHome
    low PORTD.0
    pauseus SlowHome
    next
    for i = 1 to 8800 ' was 8900
    high PORTC.3 ' move forward to final position
    high PORTD.0
    pauseus SlowHome
    low PORTD.0
    pauseus SlowHome
    next
    PAUSE 500
    HIGH PORTD.3
    ' need some error checking here
    LOW PORTD.1 ' Turn off air valve to lower turret
    CurrentTool = 1
    PAUSE 500
    LOW PORTD.3
    IndexTurret:
    ToolSlotsToMove = RequestedTool - CurrentTool
    if ToolSlotsToMove < 0 then ToolSlotsToMove = ToolSlotsToMove + 8 'only go in one direction
    StepsToMove = ToolSlotsToMove * StepsToMoveForEachTool
    Repeat
    Until PORTA.4 = 1
    for i = 1 To StepsToMove
    high PORTD.0
    pauseus speed
    low PORTD.0
    pauseus speed
    next i
    HIGH PORTD.3 ' Engage turret locking air cylinder on
    PAUSE 500
    LOW PORTD.3 ' Disengage turret locking air cylinder off
    CurrentTool = RequestedTool
    Ohio
    Thanks Dave.
