error
Results 1 to 7 of 7
Thread: error
    Default error
    Greetings,
    I'm trying to make a blinking led program for a 10F206 pic.
    The program is just a learning step to see how this little pic works.
    I already made programs for many different pics without problems, but this one i get an error when compiling.
    I'm using microcode studio and the error i'm getting for this microcontroller is:
    ERROR Line 16: Redefiniton of LABEL TRISIO. (10f206.bas)
    ERROR Line 17: Redefiniton of LABEL GPIO. (10f206.bas)
    ERROR Line 21: Redefiniton of LABEL CMCON0. (10f206.bas)
    I get these errors even with just 2 lines of code like:
    TRISIO=%0000
    GPIO=0
    what do these errors mean ?
    TRISIO = %0000
    GPIO = 0
    GPIO.0 = 1
    Pause 100
    GPIO.0 = 0
    Pause 100
    Goto Main
    Works here, with PBP2.60. I'm assembling with MPASM as I can't use PM on Win7.
    Have you selected the correct PIC in the drop-down list in MCS?
    Nov 2007
    West Covina, CA
    Default Good here too
    Compiled good with PBP2.47 and MPASM using Henrik's sample.
    Louie
    Greetings,
    Thanks for the help.
    I'm not being able to compile without these errors. Tryed MPASM and PM without success.
    With Henrik's sample i also get these:
    ERROR: RAM END must be defined.
    ERROR: RAM BANKS must be defined.
    I guess it's time to do some fomat c: :S
    malc-c's Avatar
    malc-c Guest
    TRISIO = %0000
    GPIO = 0
    GPIO.0 = 1
    Pause 100
    GPIO.0 = 0
    Pause 100
    Goto Main
    Compiles fine for me too ver2.60, with MpSAM 5.06 and Vista 32bit
    Try changing the file name to something other than the chips part number.
    There is already a 10F206.bas file in the PBP folder that is loaded automatically during the compile.
    But instead it will find your source code again.
    hth,
    Thanks guys for all the help,
    i've tryed everyting including your tips but i still get errors.
    I belive it's something related with the pc it self. I will have to re-install everything.
    Thanks again
