I get a lot of errors trying to compile it with PicBasic. But it looks like it is written in C. There are a lot of C forums out there though. You probably will have much better luck there.
WARNING Line 23: Bad token "{".
WARNING Line 29: Bad token "{".
WARNING Line 32: Bad token "}".
WARNING Line 33: Bad token "}".
ERROR Line 11: Syntax error. (Untitled.pbp)
ERROR Line 12: Syntax error. (Untitled.pbp)
WARNING Line 12: 4000000 Numeric overflow, value truncated. (Untitled.pbp)
ERROR Line 14: Syntax error. (Untitled.pbp)
ERROR Line 15: Syntax error. (Untitled.pbp)
ERROR Line 16: Syntax error. (Untitled.pbp)
ERROR Line 18: Syntax error. (Untitled.pbp)
ERROR Line 20: Syntax error. (Untitled.pbp)
ERROR Line 22: Syntax error. (Untitled.pbp)
ERROR Line 24: Syntax error. (Untitled.pbp)
ERROR Line 25: Syntax error. (Untitled.pbp)
ERROR Line 26: Syntax error. (Untitled.pbp)
ERROR Line 27: Syntax error. (Untitled.pbp)
ERROR Line 28: Syntax error. (Untitled.pbp)
ERROR Line 30: Bad expression. (Untitled.pbp)
ERROR Line 30: Bad expression or missing THEN. (Untitled.pbp)
ERROR Line 30: IF without a matching ENDIF. (Untitled.pbp)
ERROR Line 31: Syntax error. (Untitled.pbp)
