accessing fram memory
Results 1 to 9 of 9
    servo260's Avatar
    servo260 Guest
    Default accessing fram memory
    Hi, I have a FM24C04A (fram memory from ramtron), and I want to access it usin a 16f627. Here is the code I wrote to do some tests (it's part of a bigger code).
    What I want to do is to write a 5 (decimal) in some adress and then read it and write it to a variable, then send the variable to a display.
    I was experimenting with shiftout and shiftin, but I don't really know what I am doing.
    The memory uses the same pin to read and write, I tried to use also only one pin on the pic, Is it possible?
    @ DEVICE INTRC_OSC_NOCLKOUT, WDT_OFF, PWRT_OFF, MCLR_OFF, BOD_OFF, LVP_OFF, CPD_OFF, PROTECT_OFF
    include "modedefs.bas"
    define osc 4
    TRISA = %00000000
    TRISB = %01000110
    intcon = 0
    clear
    num var byte
    x var word
    cuenta var byte
    velocidad var word
    circunferencia var byte
    demora var byte
    t1 var portb.4
    t2 var portb.5
    t3 var portb.3
    sda var porta.7
    scl var porta.6
    timer con 9
    OPTION_REG = %10000111
    INTCON = %11100000
    CMCON = 7
    shiftout sda, scl, 5, [%10100000, %00000000, 5]
    shiftout sda, scl, 5, [%10100000, %00000000, %10100001]
    TRISA.7 = 1
    shiftin sda, scl, 7, [circunferencia]
    TRISA.7 = 0
    x = circunferencia
    display:
    num = x dig 0 ; unidad de X y lo manda a num
    porta = num
    high t1
    pause 3
    low t1
    num = x dig 1 ; decena de X y lo manda a num
    porta = num
    high t2
    pause 3
    low t2
    num = x dig 2 ; centena de X y lo manda a num
    porta = num
    high t3
    pause 3
    low t3
    goto display
    As i know those 24c04 are I2C device... you must use I2CREAD and I2CWRITE
    servo260's Avatar
    servo260 Guest
    Can you give me a code example? I never use memories before.
    What I don't understand is the "control" in the i2cwrite command.
    Have a look to the PBP manual.
    Have a look to this code from Melabs website
    and much on this forum.. search for I2CREAD and I2CWRITE
    servo260's Avatar
    servo260 Guest
    this is what I have done, I changed this
    TRISA.7 = 1
    TRISA.7 = 0
    to this
    i2cwrite sda, scl, %10100000, %0000000000, [%00000101]
    i2cread sda, scl, %10100001, %000000000, [circunferencia]
    But the display shows 128 and not 005
    your adress must be 8 bits long.. not much. And you don't need to change you control word... PBP will do it for you.
    also refer to your datasheet about the Twrite delay. some will need few milliseconds before the write cycle is finish.
    so try
    i2cwrite sda, scl, %10100000, 0, [5]
    pause 10 ' safe delay
    i2cread sda, scl, %10100000, 0, [circunferencia]
  1. Fram Memory
    By MARGARITA in forum Serial
    Last Post: - 1st October 2008, 13:30
  2. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  3. Replies: 4
    Last Post: - 2nd March 2007, 06:12
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 02:37
  5. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 18:38
