Ds1820 -> pid -> pwm
Results 1 to 24 of 24
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by gadelhas View Post
    @ malc-c , if possible put the code here as you had mension. I would appreciate.
    To be honest you could use the code attached to my first post in the thermostat thread http://www.picbasic.co.uk/forum/showthread.php?t=12712
    You would need to build / breadboard your hardware to match that used in the included hardware file.
    @ HenrikOlsson, I'm reading and trying to understand your PID routine, i will post some questions soon about it, i have some questions!!
    The Heater resistor that i have is 220V AC, i think it's better to do, like malc-c did, with a Solid State Relay, and low speed PWM.
    I've not tried it, but I would of thought that it would be kinder on the resistive element of the aquarirm heater, especially as with it immersed in water the heater has less chance to cool as a similar element would in air. A SSR is the way to go - bit costly, but a lot safer
    @ malc-c Again. I see your video, and i think the result its really great. If you change the Kp, Ki, Kd, variables, do you see any change to the process? Like, more slow/ fast to achive the SetPoint, for instance?
    Thanks once again for everything.
    Hope you can understand my english, sorry for all the errors!
    From memory, changing the values altered things like the amount of over-shoot of the set point, the range at which the output started pulsing, and the length of pulse. The advantage with the code that Darrel and Henrick had put together was that using a serial cable and Hyperterm I was able to change the values via the PC and see what effect it had on my test rig which comprised of a heater in a wooden box with the sensor 6" below a ceramic heater. Over several weeks the values were adjusted and tuned until the temperature set point either maintained or was within half a degree either side (as you can see by the video - in the real environment it's almost spot on)
    May 2008
    Italy
    Working with ac and resistive load, phase angle control is the choice (dimmer principle), PWM works very well only with dc.
    Since you will have 50 Hz main, every half cycle will last 10 millisecs, so once you have found the zero crossing moment, you will fire your triac with a delay from 0 millisecs to max 10 millisecs.
    where:
    0 millisecs delay = 100% duty
    5 millisecs delay = 50% duty
    10 millisecs delay = 0 % duty
    Remember that your triac will turn off at every zero crossing, which make phase angle control a rather efficient and easy way to control resistive loads with ac.
    Cheers
    Al.
    Hi Al,
    I agree, phase angle control is nice but IMO overkill for a system like this.
    The heater itself and the system as whole is most likely quite "slow". Creating a low frequency PWM with a period of 1 or even 10 seconds will likely work just fine.
    That way the slight error introduced by the solid state relay (or triac) not shutting off until next zero-crossing can be disregarded. (Max 1% with 1s period or 0.1% with a 10 second PWM period.) Depending on if the SSR is "random firing" or not it'll be a little bit different but still good enough IMHO.
    Of course it depends on the power of the heater, the amount of water in the tank and the amount of "temperature ripple" you can tolerate but I don't think the tank will "respond" fast enough that a 1 or even 10 second PWM period won't work.
    May 2008
    Italy
    Hi Henrik, Let me say that I could accept your statement only if we talk about an amatour project. But since the OP opened the thread with the following statement:
    I need to do a university project, for "Computer Control. The project consists of performing a PID controller based on a Microcontroller.
    In this case I will expect from him to challenge the highest performace he could think of.
    He will be a tomorrow electronic designer and he will have to face an extremely aggressive global market, so I do expect from him something more than "something that will likely work just fine"
    Herik, I Hope you will agree with me!
    Cheers
    Al.
