variable modifiers / aliases...
Results 1 to 6 of 6
    hmmm, never used select... I'll look it up in the manual for some bedtime reading...
    Thanks for that aratti.
    Edit: i looked in the manual, it doesn't specify if select case is used once or is 'ran' whenever you want to update?
    May 2008
    Italy
    I suggest you to place the snippet in a subroutine and call it, with a GOSUB, all the times you need to change your torque setting.
    Al.
    Thats what i thought...
    I think i'll put all three in an 'update' subroutine since at the moment it's only called twice, one at initialisation and once when you hit the 'go' button. however, a later revision may decide that you can change these settings while it's running...
    thanks again aratti
    Mar 2005
    Cocoa, Florida
    Default Torque - jumpers
    If you really need soft then Arrati has it.
    Personally, I would start a project like that with torque select jumpers on the board and save precious pins for the feature creep you know is coming.
