simple flashlight LED - NEW to pic 12f629 -
Results 1 to 7 of 7
Threaded View
  1. #5
    Oct 2010
    Talking
    itried to do the following.
    i have to buttons...one increase the brightness and the other decrease the brightness.
    but is not very smooth. I have also a problem to turn off the LED.
    For remind you, i need a code for making a flashligh like this:
    @ DEVICE  PIC12F675,INTRC_OSC_NOCLKOUT ' internal RC osc
    @ DEVICE  PIC12F675,MCLR_OFF           ' Disable external MCLR
    @ DEVICE  PIC12F675,WDT_OFF            ' Disable WatchDog timer
    @ DEVICE  PIC12F675,PROTECT_OFF        ' Disable device protect
    @ DEVICE  PIC12F675,CPD_OFF            ' Disable Code-Protect
    INCLUDE "bs1defs.bas"
    ansel = 0
    GPIO = 0
    TRISIO = %00001100 			' GP2 as input and set GP 0,1,3,4,5 as outputs
    CMCON  = 7
    ADCON0 = 0 ' A/D off
    signal VAR BYTE
    signal=5
    Start:
          IF gpio.2=0 THEN
             signal=signal+1
             IF signal>10 THEN signal=10
             pause 150
          IF gpio.3=0 THEN
             signal=signal-1
             IF signal=255 THEN signal=0
             pause 150
          HIGH gpio.0
          PAUSE signal
          LOW gpio.0
          PAUSE (10 - signal)
          GOTO Start
    you can see also there people trying....
    http://www.candlepowerforums.com/vb/...d.php?t=192206
