simple flashlight LED - NEW to pic 12f629 -
Results 1 to 7 of 7
    Oct 2010
    On the following code, which the 100% i took it from the link you already gave me, i manage to place my won PWM code.
    The problem is that i cannot make the LED to stay at the specific brightness i gave to the PWM.
    Also at the moment it is also difficult for me to place more than one britghness.
    As i told you i would like to make the button to control one led but when i press once the button to have 10% of brightness then press again and have 50% and then pressed again 100%.
    If there is any help for this please, and i will keep trying to understand better the sequence of debounch.
    thank you again for your help.
    Best regards.
    INCLUDE "bs1defs.bas"
    cnt VAR BYTE
    delay var byte
    boton VAR GPIO.2
    led VAR GPIO.1
    ANSEL = 0 '12F675 for test
    CMCON = 7
    OPTION_REG.7= 0 'Pullups enabled
    WPU = %00000100
    steps VAR WORD
    cycles CON 2
    cnt = 0
    GPIO = %00000110 ' Nosurprise startup ...
    TRISIO = %00000100 ' GP2 as input and set GP 0,1,3,4,5 as outputs
    Detect: 'Button presses W/Debounce
    delay = 0
    BUTTON Boton ,1,255,0,delay,0,pressed
    'Pin,Down,Delay,Rate,BVar,Action,Label
    ' Slow Things down
    GOTO Detect
    Pressed: ' Some > 10ms press detected
    IF cnt <=1 Then 'tocount uptu 3, bigger values will add up.
    cnt = cnt + 2
    cnt = 0
    For steps=0 TO 100
    PWM led,steps,cycles
    Next
    'in here what can i type in order the LED to stay at the specific brightness???
    WHILE !Boton : WEND ' Wait Boton release !!!
    goto detect
    Oct 2010
    Talking
    itried to do the following.
    i have to buttons...one increase the brightness and the other decrease the brightness.
    but is not very smooth. I have also a problem to turn off the LED.
    For remind you, i need a code for making a flashligh like this:
    @ DEVICE  PIC12F675,INTRC_OSC_NOCLKOUT ' internal RC osc
    @ DEVICE  PIC12F675,MCLR_OFF           ' Disable external MCLR
    @ DEVICE  PIC12F675,WDT_OFF            ' Disable WatchDog timer
    @ DEVICE  PIC12F675,PROTECT_OFF        ' Disable device protect
    @ DEVICE  PIC12F675,CPD_OFF            ' Disable Code-Protect
    ansel = 0
    GPIO = 0
    TRISIO = %00001100 			' GP2 as input and set GP 0,1,3,4,5 as outputs
    CMCON  = 7
    ADCON0 = 0 ' A/D off
    signal VAR BYTE
    signal=5
    Start:
          IF gpio.2=0 THEN
             signal=signal+1
             IF signal>10 THEN signal=10
             pause 150
          IF gpio.3=0 THEN
             signal=signal-1
             IF signal=255 THEN signal=0
             pause 150
          HIGH gpio.0
          PAUSE signal
          LOW gpio.0
          PAUSE (10 - signal)
          GOTO Start
    you can see also there people trying....
    http://www.candlepowerforums.com/vb/...d.php?t=192206
    Here is something more. You will need to refine it.
        CNT VAR BYTE
        BUT VAR GPIO.2
        LED VAR GPIO.1
        cnt = 0
        CHECK:
        IF BUT = 0 THEN TICK
        GOTO CHECK
        TICK:
        PAUSE 100
        CNT = CNT + 1
        IF cnt = 1 THEN DIM
        IF cnt = 2 THEN BRIGHT
        IF CNT => 3 THEN LED_OFF
        GOTO CHECK
        DIM:
        PWM LED,75,100
        GOTO DIM
        BRIGHT:
        HIGH LED
        PAUSE 100
        GOTO BRIGHT
        LED_OFF:
        LOW LED
        PAUSE 250
        CNT = 0
        GOTO CHECK
    Oct 2010
    Thank you mackrackit,
    i will try the code later and let you know. When i finish the circuit and the code i will post it here.
