driving multiple 16x2 LCDS
Results 1 to 5 of 5
    Aug 2005
    Michigan, USA
    Just curious why you use 3 pins instead of just 2 pins for the two Enable signals in that circuit?
    Oops! Never mind. It allows you to use a single driver and a single pin for the E signal. Duh!
    i thought today at work of using two 2 input AND gates on the enable lines and use a second enable line... but, disable works... lol
    May 2008
    Italy
    You can use an 8 channels analog mux (74HCT4051), where you connect the pic enable pin to the input and the 8 outputs to 8 different LCDs (with a pulldown resistor). with three extra I/O pic pins you will select the proper LCD address using the selector line S0;S1;S2.
    Cheers
    Al.
