TLL Logic? reading 3.3v on a pin?
Results 1 to 5 of 5
    Nov 2006
    Murrieta, CA
    Default TLL Logic? reading 3.3v on a pin?
    Ok here is the setup
    Pic basic pro
    PIC16F877A via ICSP
    I have a 5vdc board but i have an RF section which requires 3.3v this RF section has an output logic of 3.3v connected to ports A0 - A4 ... the problem i am having is ports A0 - A3 which are TTL. Porta.4 which is an Schmitt trigger input reads the low voltage just fine its the other ports that i get no response with..
    do i have to do a special config for these 4 ports?
    Setting the TRISA register has no effect.
    is there another register i am missing?
    There are 10 kinds of people. Those that know binary and those that do not.
    Feb 2010
    USA, New England
    Add the lines:
    ADCON1=7
    CMCON=7
    Near the top of your program. This should set your analog ports as digital. Then the TRIS register will have an effect.
    Best Regards,
    Paul
    Dec 2005
    Quote Originally Posted by RFEFX View Post
    Porta.4 which is an Schmitt trigger input reads the low voltage just fine...
    I would expect more trouble with the Schmitt trigger which requires 0.8*Vdd or 4V for logic high.
    Anyway, I usually use the circuits shown in FIG 13 or FIG 14 in this App Note http://www.zbasic.net/appNotes/AN213.pdf
    Nov 2006
    Murrieta, CA
    i agree but found that the following works well with it.
    IF porta.4 != 0 then <label>
    Thnx for your help guys
    Hangover, Germany
    Cool
    Forget all this TTL-things !
    You are in the CMOS-decade !!!!
    No one is using TTL-Logic !!!!
    Just look in the datasheet and look at the functions of each post-pin !! there is a lot of surprise !!!
