Hash functions
Results 1 to 4 of 4
Thread: Hash functions
    Feb 2005
    Holmfirth England
    Hi
    If your using a 4MHz osc you could try using 20MHz, that would be 5 upto times faster, depending on the commands used.
    Bob...
    Dec 2003
    Wichita KS
    Hello Ioannis,
    I>>Does anyone have any experience with Hash Functions to code the unique iButton serial number into a memory address to find it then instantly?<<
    Ouch...Unless you can use a "function" to calculate your address directly, you are talking about time. Some Hashing routines use functions as such. The other Hash routines will probably require more time in calculating , then it would be to read the data and compare. How many items will you have?
    Can you store them in a ASCII logical order and do a Binary Search routine?
    This will limit your number of reads down. if you have 256 items (like in a table) you would find (worse case senario) 8 reads to have your value.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Thanks for the replies.
    Well a 20 MHz xtal is not the best since speeding up to 5 times is not enough. There will be an incresing number of keys and may reach up to 300 or 400. Imagine a PIC searching 400 6-8 byte numbers!!!
    The binary tree is a good option. Did not think about it.
    Thanks again.
  1. Hash function
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 7th September 2007, 10:09
  2. Functions in Pic Basic Pro
    By bumlife in forum mel PIC BASIC Pro
    Last Post: - 4th April 2007, 21:59
  3. Subs and functions
    By bearpawz in forum PBP Wish List
    Last Post: - 27th December 2006, 06:38
  4. Replies: 2
    Last Post: - 13th December 2005, 00:11
  5. Functions
    By AndyP in forum PBP Wish List
    Last Post: - 6th May 2005, 12:00
