Mark,
I'm thinking that maybe you need to move the USB interrupts to Low Priority, so that it won't interfere with the PWM interrupts.
Like this ...
DEFINE  USE_LOWPRIORITY  1
INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
INCLUDE "ReEnterPBP-18.bas"
;----[High Priority Interrupts]-----------------------------------------------
INT_LIST  macro    ; IntSource,          Label,  Type, ResetFlag?
        INT_Handler     INT_INT,     _Do_WaveMakers, PBP, yes
;----[Low Priority Interrupts]------------------------------------------------
INT_LIST_L  macro  ; IntSource,        Label,  Type, ResetFlag?
        INT_Handler   USB_Handler
    INT_CREATE_L             ; Creates the Low Priority interrupt processor
endasm
And you may need to synchronize loading the CCP registers with Timer2.
Or, use HPWM10 ... http://www.picbasic.co.uk/forum/show...7805#post37805
HTH,
